FoxBody Fuel tank options?
Old Jul 10, 2017 | 07:34 AM
Mastif's Avatar
Default FoxBody Fuel tank options?
Hey guys, I am doing a LQ4 twin turbo build, and looking for options with the Fuel tank. I currently have a 10 gal fuel Cell, with 2 lines coming out of it. the car has been running a 406 SBC on spray for the past several years.
Any input is appreciated.
Old Jul 10, 2017 | 07:40 AM
svslow's Avatar
What is wrong with the fuel cell you have?
Old Jul 10, 2017 | 09:59 AM
Mastif's Avatar
Default Fuel Tank
Maybe nothing, I have not searched for fuel pump requirements just yet, If I am lucky, I hope to be able to use my current Cell.
My build is a LQ4, 9.8 CR, Huron twin turbo kit, 317 ported heads, twin spec'd cam, PTC converter with a glide. going in a 2700 lb Fox street car.
I still need to decided on a intake & fuel system.
Old Jul 10, 2017 | 10:01 AM
svslow's Avatar
Fuel type and HP goal will dictate the fuel system requirements.
Old Jul 10, 2017 | 10:04 AM
Mastif's Avatar
Default fuel
I plan to use 93 for my street cruising, and will put 110 in it when going to the track.
Plan is to make 900-950 rwhp on the 110.
lil John with be specking the cam.
Old Jul 10, 2017 | 11:32 PM
boostedstang's Avatar
I'm building about the same setup.Im going to try to use aftermarket hanger and pump in stock tank
Attached Thumbnails FoxBody Fuel tank options?-screenshot_2017-06-25-12-24-11.png   FoxBody Fuel tank options?-img_20170625_193307_013.jpg   FoxBody Fuel tank options?-1499747416136.jpg
Old Jul 11, 2017 | 03:01 PM
Forcefed86's Avatar
Is it a full on race car? Street car? I like to use the factory tank and fill. You can pick up a new factory tank dirt cheap then have a sump welded to it. Or run a surge tank.
Old Jul 12, 2017 | 07:11 AM
svslow's Avatar
I bought an $80 tank off Rock Auto and welded on a sump. Super cheap and easy.
Old Jul 12, 2017 | 07:33 AM
Mastif's Avatar
Default Thanks
Thanks guys,
The car with be a street / track car. I was not sure if the fuel cell would even work seeing I have only 2 outlets, and no return option. I was looking for what you experienced guys have done in the past.
Old Jul 12, 2017 | 07:42 AM
svslow's Avatar
You can add a bulkhead fitting it the cell for the return.
Old Jul 12, 2017 | 09:16 AM
Nali6.2's Avatar
I have a 15 gallon cell in my car but im going with mini tubs and coilovers and wanted the extra room.
Old Jul 12, 2017 | 09:41 AM
69-chvl's Avatar
A nice option I'm exploring is a 03-04 cobra dual pump tank. Close to drop in for Fox's and sn95's, and has good baffling. I would run (1) factory pump of choice, and have the 450 kick in when needed. Lotta options for fuel pumps/combo's here. And the factory fuel level sender is retained. Can get pricey, but what the hell isnt.
Given a choice, I'd rather avoid having anykind of fuel or part of the fuel system in the car, or a sump welded. The sump you risk a sh!tty job being done (which happened personally to me) resulting in leaks, and the sump doesnt offer any baffling advantages.
Old Jul 12, 2017 | 10:16 AM
Longblue's Avatar
Look up Behind Bars Race Cars or Glenns. Both make fabbed tanks for the fox. Looking at these for when I get to that point on my coupe project.
