Help. Best rear end gears for my twin turbo build.
Old 07-20-2017 | 06:13 PM
dlandsvZ28's Avatar
Originally Posted by moe4541
I'll have to call the shop who built the trans to get the gesr ratio
This might help.
http://www.tciauto.com/tc/gear-ratios/
Note the difference between 1st gear in the 350 vs 1st gear in my 4le60 (1998 Z28). Compare final gear too: 1.0 vs .70 in the 4le60.
Old 07-20-2017 | 08:49 PM
simple's Avatar
Originally Posted by dlandsvZ28
This might help.
OD in the 4l60 is .70 but 3rd gear is 1:1 just like a turbo 350.
Old 07-21-2017 | 07:28 AM
dlandsvZ28's Avatar
Agree but the OP stated he wants good street and cruising manners, not a race/drag car.
So the TH350 with only three gears will be 1:1 when cruising. So IMO there will be a big difference in rpm cruising at 75 mph with 3.42 gears vs 3.08 or numerically lower gears - 2.73 gears for example since no 4th gear or OD.
Old 07-22-2017 | 08:50 AM
moe4541's Avatar
I'm tracking with gear ratio but when throwing the turbos and the higher stall into the mix I'm lost.
two 68/70s
3200 stall
Old 07-29-2017 | 08:57 PM
moe4541's Avatar
You recommending 3.08 or 3.42 gear?
Old 07-29-2017 | 09:33 PM
jimmyg's Avatar
I would go 3.08 if you do a lot of highway driving . You will have plenty of torque to get moving.
Old 07-29-2017 | 09:41 PM
jimmyg's Avatar
3.42= 3078rpm@75mph. (28in tire)
3.08= 2700 rpm@75 mph. 28in tire)
3rd gear turbo 350
Old 07-29-2017 | 11:03 PM
moe4541's Avatar
I'll hit the highway every now and then. 90% will be street time. Driving around town.
Old 07-29-2017 | 11:09 PM
moe4541's Avatar
3rd gear turbo 350
How do I calculate when I'll spool for boost. and what RPM will it kick in....3200-3400 stall. (2) 68/70s.
Quick Reply: Help. Best rear end gears for my twin turbo build.
