MSD 6014 - 2.5 bar map WTF!!!!!
Old Jul 25, 2017 | 10:31 AM
tittan1500's Avatar
Originally Posted by Nali6.2
well I think the first mistake was downgrading a ls motor to carb and msd.....
Car had a NA 632 with a power grid setup. When that threw a rod I had to build a setup quick and use what I had.
The fuel system was in place for the power with a carb and it made the swap easier and cheaper.
I planed on going EFI at some time, but these dam carbs just work lol
Old Jul 25, 2017 | 02:09 PM
stevieturbo's Avatar
If the carbs work and you're happy with them, and you know what you're doing...then just go ahead and use the ecu for ignition only. It'll give you good insight anyway you can decide if you then want to move to EFI.
Old Jul 25, 2017 | 10:06 PM
Ben.'s Avatar
Just keep the MSD box, run as much boost as you want and tune the last two rows on the load scale to suit
