MSD 6014 - 2.5 bar map WTF!!!!!
Well my mistake but i just realized this box can only go to 21 lbs of boost!!!
What the hell MSD, hey lets go release a new box for LS guys and limit the **** out of it. Its not the days of 6 psi roots superchargers anymore.
Anyways end of rant....
Any one found a work around or what box do you use for non EFI stuff?
Might want to look again.
I might need to sell this box in the first year.
So you can use any map sensor you want, for any boost range you want. It may not correlate with correct numbers within your software, but it will still be perfectly functional.
The old box you could use any sensor, but this box the sensor is inside the box and you run the air line to the box
Not sure why MSD decided to do this, and then use such a low MAP.
I could see if they were trying to force people to use the power grid.... I had that but to convert a LS to use it costs stupid money. so thats not MSDs game plan.
Does anyone know what MAP the Datona sensors unit can use?
You could just max the sensor out and tune like that. No ideal, but done by many over the years for any load sensor.
Or much as wastegates are fooled into thinking there is less boost there....you could create a small bleed on the signal line to the sensor. It might take a little bit of testing to get it where you want. But it should give repeatable results and the signal from the sensor would always just be less than actual boost.
Both are easy and free options, even if not ideal
To do that on the stock 5.3 heads i need about 30 lbs of boost for 900s at the tire.
MSD said the sensor when maxed will hold the last timing value, so once I pass 21 lbs you better have the timing you want in that cell for 25 or what ever boost you are going to run.
My issue is that I have seen peoples cars over boost or make more than the tune expected because of melted waste gate lines or heavier engine loading. and boom no more head gaskets.
Depending on budget, you'd almost be as handy buying a proper ecu, and if you are using a carb, just ignore the fuel side of things and let it run ignition only. But a decent ecu will allow you other features like overboost protection, you could add widebands and log fuel to help with tuning etc.
And at a later date if you decided you wanted to go EFI, the main controls are already in place.
I was going to buy a electric boost controller and i can sell my current box.
Between saving on the boost controller and selling my current box that makes the swap a no brainer
I always ran a sbc with a 6al and boost timing master and worked well but this is my first foray into the blow through ls world.
When the time comes at least I have a heads up on options.
Some features may prefer fuel cuts, but most you can select between fuel cuts or spark cuts. In the case of ignition only you'd only have access to spark cuts, whether for say rpm limiter, overboost cut, 2step etc etc.
But a fully featured ecu just opens up more options to you.
i run a daytona sensors box with a blow through carb from csu and it is flawless.... it measures in inches of mercury but you can run a 2 or 3 bar map sensor... Dennis is great with tech help and even sent me a tune to start..... very simple to use and worth the money.... harness is very tidy and from what Dennis explained to me it is more accurate under high rpm and reads actual timing ... I guess msd can vary and is not "actual timing"
