What Solenoid For Boost Control On MS
Old Jul 21, 2017 | 08:35 AM
2JZFC's Avatar
Default What Solenoid For Boost Control On MS
Installing an EFISource Gold Box for a buddy and wondered what solenoid folks are using for boost control. EFISource said to search the Sloppy site but I could not find it.
TIA,
Old Jul 21, 2017 | 08:40 AM
svslow's Avatar
http://www.ebay.com/itm/NEW-MAC-BOOS...xXYLkc&vxp=mtr
Old Jul 21, 2017 | 12:31 PM
DailyGTO's Avatar
+1 for the MAC valve, using MS and no complaints here.
Old Jul 21, 2017 | 12:45 PM
Forcefed86's Avatar
Can grab them for $19.50 from china.
This was the cheapest in the US I found, but doesn't come with the fittings.
http://www.ebay.com/itm/MAC-3-Port-E...8AAOSwvzRX0ttB
Old Jul 21, 2017 | 01:51 PM
2JZFC's Avatar
Thanks, guys.
Old Jul 24, 2017 | 06:15 PM
stevieturbo's Avatar
http://www.ebay.co.uk/itm/NEW-MAC-BO...19.m1438.l2649
Old Jul 27, 2017 | 10:08 PM
2JZFC's Avatar
How are you guys plumbing the Mac solenoid for a dual-port WG?
Old Jul 28, 2017 | 07:12 AM
shainiac's Avatar
For a dual port wastegate, I prefer running MAC 4-port solenoids. They allow you to get a wider boost range with a lighter spring so you can run lower boost on gate pressure if you want. It also allows you to put 100% of the pressure to the top of the gate during spool up which makes a bigger difference than you’d expect. For the extra $20, it’s worth it.
http://www.ebay.com/itm/MAC-Boost-So...hWRVbe&vxp=mtr
Old Jul 28, 2017 | 07:48 AM
Forcefed86's Avatar
That’s not true. A 3 port can give you just as much range as a 4-port. If you plumb it correctly.
Drill a tiny bleed hole on the top gate supply so it can vent off pressure. I used a tiny carb jet drill bit, don’t recall the size.
With this arrangement you get full boost to the lower port with the solenoid “OFF”. As you pulse the solenoid it slowly phases out the lower port and applies boost to the top port. At 100% DC the lower port sees no boost and the top sees 100%. Giving you the lowest and highest possible ranges of boost for your gate spring.
Old Jul 28, 2017 | 08:20 AM
3 window's Avatar
Thus is how I have mine setup. Works great. My dome line has a .030 hole FWIW.
Old Jul 28, 2017 | 08:56 AM
shainiac's Avatar
I've seen that work before but I've also seen that bite people in the *** when they replace the line and forget to put another hole in the line. It also works better in nylon push line than rubber hose and I'm not a fan of plastic hose rated for 150F right next to turbo stuff. Will it work? Probably. But you can also spend $20 more and have something designed to perform properly.
Old Jul 28, 2017 | 09:32 AM
Forcefed86's Avatar
Put the hole in the barb/fitting on the gate. Or in the top dome of the WG itself. Whether it’s worth it spend the extra money is a matter of opinion. Point is the 3-port can give you the same range.
Old Jul 30, 2017 | 10:29 PM
2JZFC's Avatar
Having trouble finding a .030" bit. Is a 1/16" (.0625) too big?
Old Jul 31, 2017 | 06:38 AM
3 window's Avatar
If you're using plastic tubing, heat up some welding wire and push it through. Not sure about 1/16.
Old Jul 31, 2017 | 11:13 AM
Forcefed86's Avatar
Could give it a go, but seems a little large. Local tool houses should carry "jewelers bits" or "Micro bits"
here is a link to a set.
Amazon Amazon
Old Jul 31, 2017 | 12:56 PM
roastin240's Avatar
Throw an NPT tee in there and buy an orifice fitting with the correct size hole you want. That makes a lot more sensor to me. You can plumb the tee RIGHT OFF the boost solenoid outlet to the top port and install your orifice fitting there. Much more robust option.
In the event you want to change the orifice size, you just buy a new one and swap it out till you get the wastegate behavior you want.
Old Jul 31, 2017 | 05:45 PM
You can easily buy small drill bits, plenty used them for years for drilling carb jets.
Or the most readily available small bleed orifice...0.6mm MIG tips.
Old Jul 31, 2017 | 07:15 PM
2JZFC's Avatar
Thanks, Guys.
Old Aug 22, 2017 | 01:40 PM
rt338b's Avatar
PM sent
