Size of injector
Old Jul 26, 2017 | 09:10 AM
Chris'stransam's Avatar
Default Size of injector
What is the largest injector i can use on stock ecu with out having to use a injector driver . My car is 99 ws6 . thanks
Old Jul 26, 2017 | 09:31 AM
Ping King's Avatar
You're really limited to whatever the market can supply for high impedance injectors, and what the minimum pulsewidth to idle correctly. I've used 96lb units in the past without issues.
Old Jul 26, 2017 | 12:09 PM
lmt0705's Avatar
I've run 160 bosch on stock pcm
