the colorado budget repower
after pushing to over 1000whp with the SBE and the 6.0, and the billet 80, and the 210lb injectors and the holley efi, triple billet lockup converter.
i was certainly happy with my results, and with what i learned, but i am a budget performance guy at heart and it hurt my feelings to see all the money in the truck as is, and as i created a video "what to buy 2017" that highlighted what people should buy if they "don't care to research" or have a horrible time building their own success, they can just copy a list of my favorite parts and throw them together and make 500whp for ice cream and burnouts
meaning of course, a good ceiling and build point and capable parts 500whp through an automatic is alot for people that have never actually driven something with it...
anyway i digress, so i vowed to use the parts on my list and show you guys in a build how to do it, how easy it is, results out of it and share all the info, tunes and more!
"what turbo ls stuff to buy 2017 edition"
starting of the budget colorado build
plan was to obviously make something very accessable as i always preach, so i went with a 2002 4.8l complete, with wiring harness and accessories for 500$, i said i would use the 228/230 elgin grind cam shaft because it sounds badass and works great for motor and turbo, stock ecu, stock rewired harness, readily avaiable turbo kit from VS racing with my name attached to it of course, stock Decapped injectors, and all stock hardware otherwise, with the acception of my favorite in tank fuel pump....
and again i vowed to video and show how to do it, start to finish, how easy it is, no special ****, no frills, and here we are
here is the entire project affectionately labeled
"project dont bs me"
youtube playlist
https://www.youtube.com/playlist?lis...EliGdvmbu52vYq
entire budget spreadsheet
https://docs.google.com/spreadsheets...it?usp=sharing
and here we are, i will try to summarize front to back
so i bought the 2002 4.8, sent the harness to andy bryant at lsx specialties and he rewired, i took the stock 25lb injectors and decapped them, sent them to eric derr to flow test so i could verify flow.
i got a billet 7875 turbo from viren at VSracing along with my intercooler and piping, a stock p01 ecu from the junkyard valued at 30$
installing the "sloppy stage 2" as its affectionately become known as for 240$ off ebay, and some pac1218 valvesprings both from ebay
after that i reinstalled my budget used PTC 3800 supercharged 80e converter i bought from a friend for use with this project for 400
installed all of it, rewired the car, kept flex sensor, uninstalled 2 of my 3 450 pumps so i could figure out the limits of the single pump and not BS anyone etc etc etc of course to go with the theme.
so after all was said and done i did manage to make 521whp @ 14psi 15deg at 98% injector @78% alcohol. pretty awesome
it looks like it might be showing a little bit of valvetrain instability at 6000ish more than likely because of the rowdy camshaft and single spring. but the purpose of the build was to have something that sounds rowdy, is reliable, drives nice, makes 500+whp unlocked auto, and can run flex etc
all the check boxes marked off here...
everything was documented and showed how, there is no smoke and mirrors.
i am super happy with this build and how it went, happy to show people you can stay in a budget and do this kind of thing, and happy to give people a list they can follow to build something with their kids or have fun with their friends etc.
i will be making some passes with it as is, also swapping to p59 ecu and writing a base tune for people to use with that also with narrow band 02 sensors working, then possibly doing even more testing on random things to learn of they are worth it or not etc.
updated tune cabinet page to have 3.0 scanner layout and channels to load and use if you are starting with nothing thanks to Chris Ortiz for supplying me with them i just modded them, also put up colorado tune as is, as i will probably be touching it up a little but its good enough for you guys to get in trouble, moving to p59 ecu in a week or two to focus on that for people
I'll be watching for when you change ecu's and take advantage of e85 tuning and the other benefits of the later model computers(witch I am totally clueless about)... not sure I would change over to one, but deff interested in learning their functions.
Do you think that if I do a compare and segment swap from an 08 Express P59 (with 3 bar RTT) to my existing 03 Tahoe P59 it'll work? I'm down for just giving it a go, but I don't want to brick my ****.
How did the 4.8 feel down low, esp with the cam-the 6.0 prob is better for low end performance vs a 4.8, but curious since you had both how was the
"ice cream" (lol) driveability.
I never did find a phone # for VS Racing, but he seems to email pretty quick, but I have never been much of an email type when it comes to parts selection.
Really app. all you do for the LS bunch, prob have sent shock waves thru the expensive performance industry, lol
How do you think the cast 7875 would work compared to the billet 7875 you used on this one? Is the billet worth the extra $155 if you just want a simple 500rwhp grocery getter? You made 521rwhp at 78%e, what do you think it would make on 91-93 octane gas (we don't have e85 local)?
We are doing some pump testing with multiple $23 044 clones at the moment. So far results are pretty awesome. 100+psi no problem. 2 of these inline (boost activated) with a 450 supply could bump your pressure up to 130+ range… making those 72lb injectors act like 125lb injectors for under $50. I'll send them to you after we are done with the tests if you want to play with them.
Love your videos, been watching for a few years now, i remember when you hooked up the horn of the rental Lincoln Town Car to a nitrous switch and sprayed the ***** off it
Before I went turbo ls, I played with carbed stroker small blocks and the old guys treated the information like secret recipes... it was tough learning. With your information, I had the confidence to go forward alone.
