Blower cam Swap in mind
Old Jun 29, 2004 | 04:37 PM
BIGBOS's Avatar
Default Blower cam Swap in mind
My motor is an iron block 370c.i. setup....
I'm running a 214/218 .540/.550 114lsa cam currently.....looking over my dynosheets I make peak power right before 6000rpms and it falls from there....
I'm making 462rwhp and 522rwtq currently, I dynoed through my non locking TH400 w/a 4000 stall and 12-bolt on 28" E.T.s It was seeing close to 10psi on the dyno, I see anywhere from 10-11 on the street usually.....
I got a FMIC on order, I'm going to have this installed, relocate battery to the rear (its a must for the piping) and pulley down to a 3.2".....
I want to hit about 15psi w/the setup, but I might get a boost drop from the intercooler......
I love the way the car idles/drives now, but I would really like to have peak power at 6500-6800 range, the car right now drives like a Torque monster...
I was thinking either a 230/236 .590/.600 114lsa or a 232/238 .600/.610 114lsa style cam.....will I pick up more power throughout the range?
Old Jun 29, 2004 | 05:38 PM
Inspector12's Avatar
TT-TECH Veteran
That is a huge jump in cams. I am not sure why you chose to go so much bigger at one time but maybe something in the 224/230 228/232 range I think that would make your peak around the 6500-6800 range just my thoughts PSJ is running a cam in that area I can't remember exact specs My 224/230 114lsa cam peaks around 6500 at least it should I haven't got a chance to finish the tune after falling fuel presure. I think FMS has a great cam I think it is a FM7 224/230 586/596 114 or 115 I can't remember there website has been under construction for a while give them a call Alan was real nice to me and has been great with a lot of others. Just my.02 but I am no expert try what you want who knows you could be on to something?
Old Jun 29, 2004 | 05:40 PM
BIGBOS's Avatar
I got bigger cubes over the 348, so I'll need slightly more duration I think....
Old Jun 29, 2004 | 06:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
<--- 230/236 and mine peaks at 6900 with my particular combo.
Old Jun 29, 2004 | 07:57 PM
PurEvl's Avatar
230/234 .598/.602 on 114 here. My car without the blower did 420 rwhp just to give you an idea.
Old Jun 29, 2004 | 08:04 PM
frcefed98's Avatar
You know mine, with 370 cubes I would think that you can go with a bigger cam. FMS was rec'ed above give him a call, he is by far one of the best cam spec'ers out there for the LS1. Cmotorsports has a good selection too and are very helpful, get in touch with them too.
233/244 .050 .578/.602 on a 115LSA
Old Jun 29, 2004 | 08:41 PM
NA$TY-TA's Avatar
You know mine.... almost exactly what you are wanting
230/236 .592/.602 on a 114 I called Allen at FMS and he speced me out a cam
a 236/242 .598/.608 on a 114
We pulled my motor to 6800 and i believe i would of seen more boost if i didnt have a leak.
I forgot you were only pulling the motor to 6K rpm's. That 10-11 psi is with the 3.4" pulley right.... i believe i can make 1-2 psi more with revving my motor 6-800 rpm's higher then you did yours..... what do ya think? I believe you will see a boost rise withe the new FMIC Bos. I know ScottWS6 did.
Kyle
Old Jun 30, 2004 | 01:47 AM
BIGBOS's Avatar
Yea, I hope so......yes I see 10-11 with the 3.4"
