Boost creep after installing tailpipe?
Old Aug 10, 2017 | 10:59 AM
Bad Apache's Avatar
"C" if you want it on the crossover. But it'd work better on the log manifold in the same position as "C".
Old Aug 10, 2017 | 11:45 AM
Stonerracing's Avatar
Originally Posted by turbo_outlaw
Just to be clear on the wastegate flow.. A, B or C? I'd say C
tht design usually vents into your downpipe. A little short piece of pipe that connects from ur wastegate over to the downpipe. . C is correct
Old Aug 15, 2017 | 08:37 AM
Bowtie316's Avatar
C would help but it is still only seeing flow in that direction by 1 bank of exhaust. As mentioned before, a better placement would be in the bend in the log manifold just before the turbo flange or in the turbine housing itself.
