M6 fbody turbo gear
Old Aug 12, 2017 | 08:39 PM
BS2011's Avatar
Default M6 fbody turbo gear
Ok guys help me out I've got a turbo fbody 408 m6 car as of right now it makes 727hp and 705tq with 28" tire, what's the best dragstrip gear? Car is full interior so it's a tank, and also all I have around me is 1/8th mile tracks. Thanks
Old Aug 12, 2017 | 08:42 PM
necrocannibal's Avatar
My car is a 408 turbo M6 car and I'm running a 3.42 gear but I'm running a 26 inch tire.
Old Aug 12, 2017 | 08:58 PM
Game ova's Avatar
Not sure if your setup likes to rev or not, but 3:42 sounds about right. Just for reference, my car doesn't really care to rev high..... and seemed to like 2:73s even before the th400 swap.
Old Aug 12, 2017 | 09:03 PM
BS2011's Avatar
I shift at 6300 it falls off at 6500. I have a 3.50 gear in it now, I'm just wondering if I should change it to like a 3.60 or a 3.70 I forgot to mention its a 9in also.
Old Aug 12, 2017 | 09:09 PM
Game ova's Avatar
I'm coming to steal your rear end tonight . But yea, should run fine with the ratios you mentioned being that all you have is 8th mile around you. I think the best thing to do, and most accurate... would be to use a computer type track calculator to give you the hard facts, instead of us guessing (no sarcasm).
Old Aug 13, 2017 | 09:30 AM
stoverz28's Avatar
Why not make some passes and go from there?
Old Aug 13, 2017 | 10:43 AM
BS2011's Avatar
I have it feels like a slug out of the hole. I'm just trying to see some real experience as far as gears or should I look somewhere else other than the gear.
Old Aug 13, 2017 | 11:19 AM
ddnspider's Avatar
I also ran a 3.50 gear but with a 27" tire and it wasn't a dog out of the hole. It was more about specing the turbo and tune right.
Old Aug 13, 2017 | 01:19 PM
stoverz28's Avatar
Yea I'd look somewhere else too. 3.55 gear with 28" tires here and my car does just fine out of the hole.
What kind of boost are you launching on?
Old Aug 14, 2017 | 11:02 AM
CyberGrey Z28's Avatar
What RPM are you leaving at and how much boost?
3.73s, 26 inch slick stock suspension set up has gone 1.52. Hoping a 28 inch slicks will get me 1.4x 60 fts.
Old Aug 15, 2017 | 10:31 AM
BS2011's Avatar
I'm not real sure what boost its hitting on launch I'll have to look at my logs. I have the 2-step on 4500.
Old Aug 16, 2017 | 01:04 AM
What turbo?
Is it bogging or spinning?
Post slip.
