vacuum source
Old Aug 14, 2017 | 08:48 AM
klinznilk's Avatar
Default vacuum source
Can I use this
as my vacuum source for my vacuum block for my boost gauge, BOV and boost reference for meth injection? I am obviously not using it for anything as I have removed my smog/air setup ages ago and just capped the vacuum line.
I am assuming the check valve will need removed?
Thanks
Old Aug 14, 2017 | 10:24 AM
JoeNova's Avatar
Restricted User
Yes, you can use it. If your vacuum block is double sided, it might be easier to just place it inline with the brake booster.
Old Aug 14, 2017 | 10:35 AM
klinznilk's Avatar
I am going to need a check valve for break booster though correct?
IF so anyone know where i can purchase one?
BTW if i use the one circled above do i need to remove check valve thing on it?
Old Aug 14, 2017 | 01:48 PM
JoeNova's Avatar
Restricted User
The fitting that presses into the brake boost itself is the check valve.
Old Aug 14, 2017 | 02:07 PM
klinznilk's Avatar
Awesome
I'll get some barb fittings ordered.
Do you know the hose size by chance?
