Turbo selection for 408 m6
Forged 408 lq
Stock ls3 heads
Rick crawford ls3 intake
80# ls3 injectors
355lph drop in pump
Pump 93 oct
Cam will be custom ground after turbo selection
6 speed
3.42 gears
This is a street car that does alot of roll racing. This set up will see 8psi to 15psi on the streets. Not too concerned with how much power it puts down but 750-900 would be great.
Ive neen looking at borg warnet s400 units the s475 and s480. Not looking to break the bank on an 1800 turbo if i dont have to. The s475 looks great for $600 from airwerks with the 92mm turbine but im worried my cubes might be a little steep for the 75mm compressor. Im also concerned about which a/r i should go with since im 6 speed and have to build boost every shift. Thoughts? Thanks!
Upgrade to the S480 if its a concern. They're not too much more expensive. Cam selection will help a lot with whatever power/spool you're going for.
He laid down 811 rwhp on 16 lbs. on a very safe tune with low timing.
I'd imagine he could easily top 900 rwhp just adding more timing.
He and I roll race on the street fairly often and the thing is a beast, once he gets into 3rd and 4th he walks all over me lol.
