Where are y'all getting your rings
Old Aug 18, 2017 | 11:58 AM
Skeet Skeet's Avatar
Default Where are y'all getting your rings
So where is everyone getting their piston rings? I have a stock ls2 that I'm building for boost but as I was cleaning the rings I noticed one was broken and need to order a new set. Didn't know if anyone had a particular place they were getting them on sale.
Old Aug 18, 2017 | 12:12 PM
conan's Avatar
I got my total seal rings from Texas speed, they are file fit too.
Old Aug 18, 2017 | 12:48 PM
Ok I'll check them out then. Did you file them yourself and if so, did you just use a regular file and do it by hand?
Old Aug 18, 2017 | 02:27 PM
conan's Avatar
I let my local machine assemble my short block so they did the gaps for me.
Here is what they used FYI...
https://www.summitracing.com/parts/p...iABEgLxwfD_BwE
Old Aug 18, 2017 | 02:30 PM
truckdoug's Avatar
what year ls2. some later years had a 1.2 top ring i think.
i like the mahle/PC rings summit sells with the napier 2nd
41858-CP is the part number. it's a 1.5/1.5/3.0 ring pack
Old Aug 20, 2017 | 02:46 PM
This isn't from an 06 gto. I'm using stock bottom but am hoping to make 700-800 at some point. Would the ones you recommended truckdog be good for that?
Old Aug 20, 2017 | 05:18 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Cant use 1.5/1.5/3.0 on stock ls2 pistons, or l76 or lq9. They use a 1.2/1.5/2.5.
We have a std fit ring set with steel top and napier 2nd. std oil. They run $145. They are hastings. You will want to measure them to make sure theyll fit your boost level for gap. Id use the mahle motorsports specs on that if you need it we can get that info also.
Old Aug 21, 2017 | 12:13 AM
brandon6.0's Avatar
yea the ls2 ring size is different from the standard ls pistons.
Old Aug 22, 2017 | 11:09 AM
BlwnLs1GTO's Avatar
https://www.summitracing.com/parts/sme-906000/overview/
I've used this tool for several builds. You'll want to square the rings up perfectly with the adjuster, grind down only one side of each ring. Take your time!!!! this diamond infused file takes off material fairly fast. Very light pressure at first to get a feel. Then, take some 1,000 grit sand paper and de burr the edges. all four sides of the ring.
Take one of your pistons with the top ring installed, flip in upside down and push the newly filed ring down until the piston is sitting perfectly flat on the deck. This will line up the ring perfectly for measuring the Gap. Then use your feeler gauge to measure your gap (install the gap in the 6 o'clock position. It's very easy to do. Decide what size gap you want to go with and get started. Just be careful not to take too much material off. It's easy to do this if you're careless.
Good luck
MAKE SURE TO De BURR EACH RING BEFORE YOUR FINISHED!
Old Aug 24, 2017 | 11:34 AM
Thanks for all he help guys. Are the hasting brand ones any good?
Old Aug 24, 2017 | 11:39 AM
Most piston companies use either NPR, Mahle/Perfect Circle, Hastings, or Total Seal for their rings.
