5.3 on TH350. Starter jamming on flexplate
Old Sep 14, 2017 | 09:37 AM
  #41
moe4541's Avatar
Its the time, waaaaaaaay off
Old Sep 14, 2017 | 05:36 PM
  #42
moe4541's Avatar
Is this normal? I've had someone say yes and another no. As I'm turning the engine one side would get tight and vise versa. At one point both sides had slack.
Makes me believe my chain slipped, if that's possible with these engines. I remember lining the dots initially, it was off 90*.
Old Sep 14, 2017 | 05:47 PM
  #43
Game ova's Avatar
https://youtu.be/0pes9R0h1pA
https://youtu.be/RrXVsbaRBCs
Yes, that is normal. There's no way it jumped 90 out from that little slack. My chain was the same way.... and it had very few miles on it.
Old Sep 14, 2017 | 06:11 PM
  #44
moe4541's Avatar
Ok thanks. I couldn't find much on why the tightness went from one side to the other.
Old Sep 14, 2017 | 08:07 PM
  #45
moe4541's Avatar
Got it!
Old Sep 14, 2017 | 08:18 PM
  #46
moe4541's Avatar
Old Sep 19, 2017 | 12:44 PM
  #47
moe4541's Avatar
First start up!!! Cranked right up
Old Sep 19, 2017 | 01:53 PM
  #48
mightyquickz28's Avatar
Congrats on getting her going!
Old Sep 20, 2017 | 11:11 AM
  #49
brandon6.0's Avatar
What did u come up as being the problem?
Old Sep 21, 2017 | 09:43 PM
  #50
moe4541's Avatar
Thanks!!
Old Sep 21, 2017 | 09:44 PM
  #51
moe4541's Avatar
Timing.....Crank and Cam.
Valves and rods looked good. I'm going to replace the valves before I take it to the dyno just incase of possible bent ones.
Old Apr 22, 2021 | 09:22 PM
  #52
Louie Montalvo's Avatar
So was there actually anything wrong with the starter. Seems odd it was getting stuck. Or was it just a Timing issue cause all of it?
Old Apr 22, 2021 | 09:30 PM
  #53
Woodylyf767's Avatar
This is an old thread so he may not respond. Try private messaging him possibly.
I also feel that "Timing.....Crank and Cam." is not very descriptive.
I had a similar problem trying to run my lm7 on the stand and it was the grounds that were the problem
Hope this helps
Old Apr 22, 2021 | 09:47 PM
  #54
Hope this helps
Im having the exact issue he had. I’ve tried shimming the starter and adding grounds. But it just keeps whining and won’t start. Maybe a pop or two out the exhaust sometimes
Old Apr 22, 2021 | 10:23 PM
  #55
jordoza's Avatar
So starter being shimmed wrong won't make it not start. Check and make sure you didn't plug the coil packs backwards bank to bank. So pass plug to driver coil and vice versa. I did that on my 5th generation and it would crank forever and kinda pop from the exhaust but never start.
Old Apr 23, 2021 | 08:36 PM
  #56
Do what jordoza said. If it is cranking well, and getting spark it's not a bad ground. I was also under the impression LS starters never get shimmed
Old Apr 23, 2021 | 08:56 PM
  #57
LLLosingit's Avatar
Hope this helps
I think you guys missed the meaning of his post, By "timing...crank and cam" and then him saying he was going to replace valves, I would guess he didn't have the cam crank and cam timed correctly....in other words...timing chain was not lined up and valves where hitting the pistons and not letting the engine turn over.
Old Apr 24, 2021 | 01:03 PM
  #58
Thanks for the clarification
Old Oct 3, 2024 | 08:33 PM
  #59
Kimberly1985's Avatar
Default I'm having same issue
Stock 5.3 , never been into it . Started fine in the truck , on the stand it keeps jamming starter got a new starter same issue... got a 4l80 flat flex plate , same issue . After fighting with it for an hour or so unjamming starter with flat head and having a jump box and battery set up ... adding grounds to the engine stand and the engine itself, relocating the "multiple grounds" eyelet for pcm ground directly to battery it fired once but vats is on and it shut off ... still doing same thing now and can't get it to crank just jamms starter ... help
Old Oct 3, 2024 | 09:13 PM
  #60
Jimbo1367's Avatar
Try shimming the starte down.
