98mm 403ci
Old Oct 3, 2024 | 07:14 AM
Themasterbutcher's Avatar
Default 98mm 403ci
Hey guys
2nd guessing my turbo choice
Engine is 8.9:1
Billet 8ccw 4in crank
Ppm 300m ultra I beams
Wiseco pistons
Rec heads
Stage 4 btr turbo cam 234/239 - .618 115
Ect
My turbo is a 98mm billet wheel
T6 91/102 turbine 1.15 ar
I want it a but laggy so I have room under the curve to putt around like a normal human
I'm hoping this thing fires off around the 4000-4500 rpm
Am I dreaming?
I have 1650cc injectors
Auto 4000ish stall..
I don't want instant boos but I also don't want it to spool at 6000rpm n have 1500rpm of usable boost lol
Cheers gang
Simon
Old Oct 3, 2024 | 10:33 PM
ScottStaypuff's Avatar
Lots of variables but I bet you aren't too far off. Why do you want to delay spool though? I want my stuff to spool at +/-3000rpms full throttle. If you don't want it to spool just drive around at part throttle. The turbo would have to be pretty undersized to boost at part throttle/low rpm.
Old Oct 4, 2024 | 12:29 AM
Default spool
Hey mate, I want it to have a decent area under boost as a safe zone as I'll be doing alot of highway kms in this thing as I live rural and I want some lazy rpm.
And tbh I enjoy the big hit of a laggy turbo setup.
Old Oct 4, 2024 | 12:05 PM
Black_Sunshine_99's Avatar
I'd want a bit bigger AR if it were me, its plenty of cubes so spooling won't be a problem, I'd rather have the top end flow.
I run an S484 with the 1.36AR and 96mm turbine and it spools up just fine on my LS1, I start seeing positive pressure around 3,500 rpm.
If I foot brake it a bit while rolling, it comes on pretty quickly and pretty hard.
I say run it, see how it does, you can always get another turbine housing and swap it over.
Old Oct 5, 2024 | 03:12 AM
Yeah that's what I'm thinking. I've just had a bunch of ford guys tell me it's to big. I just don't think the understand ls motors.
Old Oct 6, 2024 | 12:11 PM
Quito195's Avatar
It will be perfect for what you’re describing. I had a very similar combo except it was a garret based 88/91 with a 1.08 AR. It was pretty much instant boost so the slightly bigger wheels and AR should nail it, worst case jump it up to a 1.32/.58 housing to slow it down a little.
