Hi Flow Cats and restrictiveness
Old Sep 2, 2017 | 03:29 PM
Formula934's Avatar
Default Hi Flow Cats and restrictiveness
Hi,
Just wanted to let everyone know my experience with hi flow cats on my H/C/I D1SC 346 ls1. Heres the link to the whole process if anyone cares to take a look.
https://ls1tech.com/forums/showthrea...1873551&page=1
Long story short, I dynoed the car with 4.5" pulley and it made 601/515 on the dyno with 10-11psi. Couldnt figure out why it was making so much boost. Bob mentioned the kooks hi flow cat cats may have been clogged up. I took them off and inspected them but they werent clogged however the casing was cracked, i presume from the increased exhaust pressures. So, i ordered a new TSP Y pipe with no cats and took the car out for a spin with the hp tuners data logger. I took it up WOT a couple runs and it was still fast as hell but pulled 4.5 psi @6500. This was the only change done to the car. I knew high flows were still restrictive from looking at the inside but i didnt think they were that restrictive! So i lost 5.5 psi just taking the high flow cats off!! It just proves the theory that forced induction motors DO NOT like restrictions!!!
Old Sep 2, 2017 | 08:08 PM
silvea's Avatar
I really don't see high flow cats being THAT restrictive if they are good working order. Still pretty crazy. Although if you were making 10psi and lost 5 psi you are at 5psi now? Crank that **** up!!!!
Old Sep 2, 2017 | 09:09 PM
Toes's Avatar
Yeaaaaa 5 psi? At over 600 with that setup sounds right. I bet your belt is slipping or you miss read your gauge. For what it's worth when i ditched my cats I couldn't tell a psi difference. Or a noticeable power increase. It does sound better though.
Old Sep 2, 2017 | 10:18 PM
Formula934's Avatar
Its reading right off the 2 bar map, I know its right. Have you looked at the "high flows" they are very restrictive.
Old Sep 3, 2017 | 12:38 AM
silvea's Avatar
I won't argue that high flows can create a restriction. That level of restriction though? Questionable. And making 600+ on 5psi would be insanity. Either way I'm glad your ride is working well and hauling ***
