Twin Turbo 4.8 Results / Single 80mm Build
Old 10-07-2018, 07:49 PM
  #261
svslow's Avatar
What alt. pulley are you running, looks huge. Any trouble with it charging at idle?
U still on oem head bolts? factory TTA spec?
Its a KRC Power Steering pulley, 3.5" diameter. With the stock pulley my voltage would drop to low 12s over 6900. No issues charging at idle. Engine warmed up, fans on, both fuel pumps and lights on it will still hold 13V. I put ARP head bolts on this one.
Old 10-07-2018, 07:51 PM
  #262
svslow's Avatar
Originally Posted by Nismo Kid
This thing is moving out. It's awesome to see a SVO getting love. Congratulations on the pass. Still rocking the btr stage 2 TT cam? This build is inspirational for me as a 4.8 turbo guy. You've gained another subscriber keep up the bad *** work.
Thanks! Yes, I am still using the twin turbo cam in this 5.3, I still have my 4.8 in the garage for back up. Going back out to the track this weekend, hoping to see an 8.6x @ 160.
Old 10-07-2018, 07:53 PM
  #263
3 window's Avatar
What’s the biggest difference you see going to the single (other than one less turbo/for all the wise guys here)?
Old 10-07-2018, 08:03 PM
  #264
svslow's Avatar
Too much has changed for me to really compare the two. The twin set up was in a low compression, iron block 4.8. New set up is an aluminum 5.3 and I've got the dome control now, which I didn't have last year. On the street the new set up is definitely more responsive, but its got a bigger motor, car is lighter etc. One of the main reasons I did the single was to be able to run a full exhaust easier.
Old 10-07-2018, 08:30 PM
  #265
3 window's Avatar
Understood. Full exhaust is awesome. I’m sure it’s holding me back a little, but it sounds tame and isn’t obnoxious drivin around.
Old 10-17-2018, 09:22 AM
  #266
svslow's Avatar
Went to the track for the final time this year. Was a pretty good day. Got an 1/8 and 1/4 ET best and a 1/8 mph best. The track surface was is really rough after the 1/8th mile, which caused my car to bounce around a lot and tag the limiter a few times. Which is why the 1/4 mph was down a bit.
Twin Turbo 4.8 Results / Single 80mm Build-rsgbvcx.jpg
Old 10-17-2018, 10:11 AM
  #267
Bad Apache's Avatar
Great way to end the season! Gotta love rumble strips at 150 MPH!
Old 10-17-2018, 10:16 AM
  #268
408GT's Avatar
Nice pass man!
Old 10-17-2018, 10:25 AM
  #269
svslow's Avatar
Twin Turbo 4.8 Results / Single 80mm Build-gxizhye.jpg
Old 10-17-2018, 10:51 AM
  #270
3 window's Avatar
Very nice job.
Old 10-18-2018, 11:57 PM
  #271
mightyquickz28's Avatar
Damn! Congrats!
Old 10-19-2018, 06:10 AM
  #272
svslow's Avatar
Thanks guys.
Old 01-02-2019, 01:43 PM
  #273
2006 z51 vette's Avatar
do you have any photos of your exhaust system?
I am going a VS single 80mm turbo in a fox body and want to do full exhaust at well...
Old 01-03-2019, 09:53 AM
  #274
svslow's Avatar
If you scroll back thru some of the old pics there are a few shots of it. The downpipe dumps on the passenger side through an electric cutout. There there is a 2.25" T off the downpipe that goes out to the rear axle with a muffler.
Old 01-08-2019, 08:49 AM
  #275
sbdgbody's Avatar
congrats, (great build) and for running mid 8s
Old 02-12-2019, 10:19 PM
  #276
Just got around to ordering a Furick #12 Fupa Cup for my welder. Sure enough, the welds are looking a lot better from just that change. Thanks for the tip.
Furick #12 fupa cup, 3/32 2% Lanthanated tungsten and 0.045" ER308L filler.
Old 02-13-2019, 06:30 AM
  #277
svslow's Avatar
Glad to hear it! That thing was a game changer for me.
Old 02-13-2019, 06:47 AM
  #278
svslow's Avatar
Quick update -
Switching up a few things on the car. Mainly going to focus on 1/8th mile racing this year. Got a pile of parts waiting to go in. Bought a BTE cased Powerglide with all the typical good stuff inside it. 1.80 gear set, 8 clutch drum, Vasco input etc. Switching to a 4.10 rear gear. Also ordered a Forced Inductions S485 from Huron Speed.
Setting a goal of 5.25 @ 135 for the season.
Twin Turbo 4.8 Results / Single 80mm Build-txdcghd.jpg
Working on a new crossmember.
Twin Turbo 4.8 Results / Single 80mm Build-j7lbhzs.jpg
Twin Turbo 4.8 Results / Single 80mm Build-98wubda.jpg
Twin Turbo 4.8 Results / Single 80mm Build-80ekhrj.jpg
Twin Turbo 4.8 Results / Single 80mm Build-uc4samm.jpg
Getting rid of all the poly rear suspension bushings
Twin Turbo 4.8 Results / Single 80mm Build-s7h1xhm.jpg
Making a coolant expansion tank as well
Twin Turbo 4.8 Results / Single 80mm Build-b0pm7uc.jpg
Old 02-13-2019, 08:29 AM
  #279
80/TA/LT1's Avatar
Is the th400 for sale now ? 🤔
Old 02-13-2019, 09:12 AM
  #280
svslow's Avatar
I sold it late last year to a local guy.
Quick Reply: Twin Turbo 4.8 Results / Single 80mm Build
