vic intake over holley mid ram with boost
Old Sep 17, 2017 | 05:05 PM
transam001's Avatar
Default vic intake over holley mid ram with boost
i am running a mid ram right now making just shy of 1100 wheel at 20 lbs. i just did hed gaskets and pro efi so i have to have the car tuned still. would i benfit switching intakes at this time. i dont want to go high ram because i want to keep the stock ss hood. thanks
Old Sep 20, 2017 | 08:42 AM
Nali6.2's Avatar
from everything I read a damn stock intake would pick up over the mid ram. I would change it out
Old Sep 20, 2017 | 11:25 AM
89BANDIT's Avatar
^ Was gonna say same thing. Mid Ram leaves ALOT on the table. Every other intake option would be better.
Old Sep 20, 2017 | 04:34 PM
stevieturbo's Avatar
Stock probably better than either of those intakes !
Although I doubt you'd expect a huge power difference either way, probably better to spend the money elsewhere unless the replacement intake is cheap.
Stock intake would probably gain more low-mid range, and similar up top.
Old Sep 20, 2017 | 05:14 PM
transam001's Avatar
i dont want to go back to the stock one. i may look into a proflow from edlebrock. i do like the way it looks though i wish a high ram would fit under the stock hood
Old Sep 20, 2017 | 05:55 PM
For low profile ? Holley Sniper ? Although quality on that one seems hit or miss...
Or this ?
https://www.corvetteforum.com/forums...manifolds.html
Or if it ever appears
https://lodspeedworks.com/
https://ls1tech.com/forums/forced-in...ng-intake.html
Some n/a intake tests...still valid data, LS3 heads
http://www.lsxmag.com/tech-stories/e...ake-manifolds/
Cathedral heads
http://www.hotrod.com/articles/20-ls...ifolds-tested/
With boost, boost can help carry the power up top, even if the intake maybe doesnt want to shine there.
But a good intake could be used to boost performance at the lower end or off boost if something was lacking there.
Maybe more useful with laggy turbos than say a centri blower.
Old Sep 20, 2017 | 06:13 PM
transam001's Avatar
thats a badass intake g1pro
Old Sep 20, 2017 | 06:23 PM
Although even with the graphs they posted....
Stock and very much so the MSD Atomic seem to blow it away in terms of real world performance.
