LS3 head gaskets and ring gaps for boost
Old Sep 25, 2017 | 03:36 PM
RonSSNova's Avatar
Default LS3 head gaskets and ring gaps for boost
I have a new engine here at the shop that a customer bought for his 2010 Camaro SS.
complete and ready to drop in.
It' an LS3 stroked to 416".
Well, not quite.
When changing the pan pan I noted it had a 24X crank wheel in it. Removed crank. Noted no barbell.....and no front galley plug either. Along with a timing chain setup with no provisions for the cam sensor.
Decided I better check ring gaps. First piston measured was .019" top ring.
Also noted 5 layer GM head gaskets copper sprayed.
So in thinking .025 top and maybe .028 second for the gaps?
Also do LS9 gaskets work well with the LS3? I certainly can't reuse what came off it.
Thanks
Ron
Old Sep 25, 2017 | 04:06 PM
3 window's Avatar
Id be worried about the whole thing after your findings. LS9 gasket bore is huge, should work. Any idea what rings are in it? Id ollow the mfg spec or if they’re gm, your guess looks good.
Old Sep 25, 2017 | 04:09 PM
408GT's Avatar
I run LS9 gaskets on my L92 (same bore as LS3) and did .026 top and .028 second.
Old Sep 25, 2017 | 07:08 PM
RonSSNova's Avatar
No clue whose rings. Might be Mahle Pistons. No name on the rods. Eagle crank.
Cyl 1,3 were .019 both rings. Obviously done with a file. Cyl 5 and 7 were more like .028/.030. Funny ****. Do they make a tool to make the gap smaller? 😊
Havent done the others yet. I'll also measure the piston to bore clearance.
thanks for the gasket info. I'll get a pair coming.
Old Sep 26, 2017 | 07:05 AM
Bad Apache's Avatar
With the findings so far, I'd measure everything before ordering any parts. lol
Old Sep 26, 2017 | 01:14 PM
Lsxford's Avatar
Id be pissed if it was me. Id be calling who i got the motor from and asking some questions.
Ron, good job investigating further. How much did the customer pay for this ready to run engine if you dont mind me asking?
Old Sep 26, 2017 | 04:23 PM
Black_Sunshine_99's Avatar
As a consumer that would be enough red flags for me to have you tear the whole thing down and check it out.
Its nice to know there are guys out there who are attentive enough to catch potentially disastrous little issues like that as opposed to just tossing it together and finding out after its too late.
Hats off to you my friend.
Old Sep 26, 2017 | 11:27 PM
RonSSNova's Avatar
Hey thanks guys. I do my best to treat customers cars like it was mine.
I'm bummed for my customer, he is a really nice guy.
I really don't know the details on the purchase, but I imagine he is in contact with the seller.
I took it completely apart. Found another issue, one oil ring was stuck because the oil ring support rail was installed upside down.
Kind of picturing this in my Nova.......nah! prob scare me!
Ron
Old Sep 26, 2017 | 11:54 PM
truckdoug's Avatar
with the dimple(s) facing up?
i'd probably have to look at the bearing clearances if i found that
Old Sep 27, 2017 | 12:19 AM
RonSSNova's Avatar
Exactly.....!
Old Sep 29, 2017 | 06:07 AM
69-chvl's Avatar
Be careful Ron, you dont want to end up "owning" this (sounds like you do already lol).
Old Sep 29, 2017 | 09:54 AM
RonSSNova's Avatar
Hey Vince. Hope you are well.
I'm thinking the winter off after this car is gone is in order!
