Fuel recommendation
Old Oct 3, 2017 | 06:44 PM
baronsmith98's Avatar
Default Fuel recommendation
Planning my single turbo build with the motor in my sig. it is around 10.7:1 compression and I am trying to decide on what fuel. I have access to E85 and have also thought about C16 but it is so expensive. Is 93 pump out of the question for this setup? Will run an s480 up to 20psi after I get a handle on it. I also don't want to run an intercooler and want to just run meth injection. Pro flo intake with Holley EFI.
Old Oct 3, 2017 | 08:02 PM
Black89Z51's Avatar
Run 93 and meth if you're worried or E availability is spotty.
Old Oct 3, 2017 | 08:07 PM
JoeNova's Avatar
Restricted User
Signatures don't show up on mobile, or after you change them.
Run E85.
Old Oct 3, 2017 | 08:22 PM
silvea's Avatar
With 10.7:1 I doubt you can do 20psi on 93 and meth. Seems a little ambitious for E85 and no intercooler, but still doable. What is the reason behind not wanting an intercooler?
Old Oct 3, 2017 | 08:45 PM
I have no problem running an a/a intercooler I just thought it would look a little cleaner without one. Kind of leaning towards e85
Old Oct 3, 2017 | 11:04 PM
Detoxx03's Avatar
Do e85 for sure. I ran pump and meth at that cr but only at 12psi 750rwhp.
