"How Original".......Billet S480 Fox Body
Old 10-17-2017, 10:11 PM
Lawhead's Avatar
Originally Posted by svslow
You will be fine. That motor isn't too bad.
Yeah the bearings deff had some trash go through them but for 60 bucks I'll slap new ones in it for the piece of mind
Old 10-17-2017, 10:13 PM
Lawhead's Avatar
Originally Posted by Stampede4ever
Where are you getting the intake for $89.00?
Thanks.
Ebay man I picked up a
*Flame suit on*
Mid-Ram for pretty cheap so gonna use that they seem on par with the TBSS/NNBS intakes but the other intake comes with rails and such so one less step
Old 10-18-2017, 05:59 AM
Stampede4ever's Avatar
*Flame suit on*
Do you have the sellers name or link? I can't find them for that price.
Thanks.
Old 10-18-2017, 07:37 AM
Lawhead's Avatar
Looks like they sold out, throw me a PM may not use this because of the mid ram
Old 10-18-2017, 06:49 PM
Ratical's Avatar
Never even got a chance to try that E85 carb......
Looks like a nice build. Good luck with it!
Old 10-18-2017, 06:55 PM
Lawhead's Avatar
Wish when I took the dash out that the car wasn't in the shape it was man and could have used it but made the choice not too. Live and learn don't think I'll ever be buying a car I don't know where it came from ever again
Old 10-18-2017, 09:01 PM
Game ova's Avatar
Head studs and the god awful looking intake showed up
Can't beat them for 89 bucks and out perform a LS6 Intake
Man that thing looks like something straight out of star wars. In the end, it's function that matters most...... just keep the hood shut.
Old 10-19-2017, 09:32 AM
Lawhead's Avatar
Well upon further inspection of that Aluminum 5.3 found some scoring on the crank that was pretty bad and the block was sold for someone to make a stroker out of, Just gonna run the iron motor that's in it now and switch the cams without even taking it out of the car......Gonna do the Pull one head bolt throw a Stud in trick and clean it up a bit and see how long it last
Been screwed over a lot with this car, so going to have the "Screw it attitude" with the motor in the car now......With that attitude it'll likely last 3 seasons and make 1000 for 3 season
Old 10-19-2017, 09:46 AM
svslow's Avatar
I wouldn't even bother with the studs.
Old 10-19-2017, 09:48 AM
Lawhead's Avatar
You don't think so? Haven't really seen much on people pushing pushing with the stock bolts......Doesn't mean it hasn't been done though like I said, If I just say "Screw it" it'll likely last longer....
Old 10-19-2017, 09:49 AM
svslow's Avatar
Fingers crossed, I have been on stock reused bolts all year. 4000+ street miles and probably about 40 passes. Been 148mph at 3300lbs.
Old 10-19-2017, 09:54 AM
  #32
Lawhead's Avatar
Well then LOL I should be a little less than that, You ever switch them turbo's or you going to keep running them??? Mine get here Tuesday
Old 10-19-2017, 09:58 AM
  #33
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
For how cheap the china studs are I'd throw them in with ls9 gaskets and be done with it.
Old 10-19-2017, 10:07 AM
  #34
svslow's Avatar
Still running them. Going to see how far I can push them Saturday.
Old 10-19-2017, 10:30 AM
  #35
Lawhead's Avatar
They're bigger than the 6765s so if you can push em I bet you can go a bit faster if it all holds
Old 10-19-2017, 10:59 AM
  #36
I like the ribbing, ribbed for her pleasure. lol.
Stampede.
Old 10-19-2017, 11:42 AM
  #37
Lawhead's Avatar
Don't want to mess with yanking the heads at this point I'll run this 5.3 with 706 heads till it goes lol
Old 10-19-2017, 12:26 PM
  #38
408GT's Avatar
Denmah barely leaned on reused head bolts to make over 1k to the rear wheels. I think that's all he uses on his builds now.
Old 10-19-2017, 01:46 PM
  #39
svslow's Avatar
I've had bad luck with studs. Had both Chinese and ARP studs break on me. Funny enough it was the same hole on two different motors.
Old 10-19-2017, 01:47 PM
  #40
Game ova's Avatar
Overtourqing them?
Quick Reply: "How Original".......Billet S480 Fox Body
