need help random no power
Good be a failing map sensor, but I would think it would throw a code.
Drive by wire? good also be a pedal going bad, again I would think it would throw a code.
Almost sounds like the pedal isn't seeing something that tells the ECU to open the throttle blade, like a gear position-wierd
