Huron Speed - Complete kit under $3k NOW AVAILABLE!
-Huron Speed newly refreshed, proven, V1 Truck Manifold Turbo Kit
-Huron Speed Cast wheel 7875 .96 a/r Turbocharger
-Huron Speed HS-44 Wastegate
-XS-Power 50mm BOV
-Pair of Derale #16925 Cooling fans
-Racetronix In-Tank Fuel Pump Kit w/ Hotwire
-Siemens Deka Matched 80# Fuel Injectors
$2999
Purchase this combination above right here: http://www.shop.huronspeedproducts.c...V1Complete.htm
Want the same package as above but with one of our V3 Kits?
Additionally we can do this SAME package as above but substitute the V1 kit for our V3 kit for $3599.
We can also do the same but substitute for the V3 A/C Retaining Package + add in the required BMR KM013 Turbo K-member for $4299
Interested in one of the above packages? Simply click the link above and change the kit included in the drop down menu!
Cast Wheel Turbo Information!
Some new updates would be we are now also offering our 7875 Turbocharger with both BILLET and CAST wheels, check out the new Cast version here which still includes the larger 3" exit, .75 a/r Compressor cover! Yes, it is still also backed by a full 1-year warranty!
http://www.shop.huronspeedproducts.c...r-hsp7875c.htm
New Wastegate RELEASED!
Another new update would be the release of our new HS-44 Wastegate! This wastegate comes in a smaller package to better fit where spaces are tight. Also with that is comes standard with 4 spring options so you can change your boost pressures without having to purchase expensive additional springs separately, there are INCLUDED! Cast body with a billet 2-piece top hat!
Check it out here: http://www.shop.huronspeedproducts.c...EW-hs-44WG.htm
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
We have worked hard recently to get to the point where we can be a one stop shop for everything you need to not just turbo your car but get your turbo car complete!
Jon
