best boost piston
Old Oct 25, 2017 | 07:36 PM
transam001's Avatar
Default best boost piston
i am building a 402 ls for big boost. i have looked at cp, diamond, and many others. whats the best piston for say 25-30lbs.
Old Oct 25, 2017 | 07:44 PM
transam001's Avatar
i am not new to the turbo world. i have a 02 ss that makes 1064 now but i didnt build the engine. i want to do it right once so if i ever want to turn it all the way up i can. i know kinda over build it .
Old Oct 26, 2017 | 09:47 AM
toytech93's Avatar
call LJMS, 2618 pistons with steel top ring and lateral gas ports
Old Oct 26, 2017 | 10:52 AM
transam69230's Avatar
A piston without valve reliefs cut to the edge, thickest top ringland possible, and minimum .200 wall wrist pins.
Old Oct 26, 2017 | 04:34 PM
stevieturbo's Avatar
The best piston one your tuner doesnt destroy.
Old Oct 26, 2017 | 07:58 PM
transam001's Avatar
thanks for the reply i called diamond today and they are doing me set of custom pistons for my build
Old Oct 26, 2017 | 10:49 PM
Game ova's Avatar
Diamond here, seem to be doing ok.
Old Oct 27, 2017 | 10:28 AM
Forcefed86's Avatar
These are pretty tough I hear... 3000lb door cars going 7.6X @ 176 anyway... What are your power goals, weight, etc. Boost pressure doesn't mean much.
Attached Thumbnails best boost piston-45316d1218856201-5-3-rebuild-ls1-5.3-piston-004.jpg
Old Oct 27, 2017 | 10:46 AM
transam001's Avatar
goals are to make 1200 plus all day and not worry about breaking the bottom end/ car weighted 3800 with me in it turbo car, th400 trans,. its a true sreet car has heat full interior. i run pro efi also . i would like to have a easy low eight car and still be a nice street car.
Old Oct 27, 2017 | 10:55 AM
Forcefed86's Avatar
1200whp+ at 3800lbs won’t be reliable on a stock block (or crank). Should be looking at aftermarket blocks with those goals IMO. Also opens up the piston options. No reason to stick with baby cubes at that point either. Really not cost effective to stick with an LS with those goals at all. BBC would be cheaper to build.
Old Oct 27, 2017 | 11:04 AM
transam001's Avatar
i would be happy with a 8sec et really. it wont be a stock crank. i run a 370 ci now at just shy of 1100 wheel on 20 lbs. the engine is built now nothing stock
Old Oct 27, 2017 | 11:10 AM
transam001's Avatar
this wont be a cheap built were i cut corners but i really not sure if i want to go with a lsx block
Old Oct 27, 2017 | 12:36 PM
Forcefed86's Avatar
I gotcha. Regardless of the big $ rotating assy, at that power level/weight the block is not reliable. Also when you bore/stroke a stock block it weakens it. They tend to crack out between the cylinders. Guess my point is it doesn't make sense to sink tons of cash in a big $ rotating assy on a stock block. You are already around the blocks limit now at 1100ish whp... esp. if you want it reliable.
Old Oct 31, 2017 | 12:06 PM
Realcanuk's Avatar
Wiseco with gas ports.... holding up great so far.
Most of the good piston companies can make something that will work good for you.
Old Oct 31, 2017 | 12:40 PM
^ This are terrible boost pistons. It will more than likely lift the ringland at the edge where the valve relief is cut since it is the thinnest spot. I have done it two years in a row.
Now this is what you want for reliability and BIG BOOST. This is a 4.130 bore custom diamond unit for my 402 build.
Old Oct 31, 2017 | 12:44 PM
Realcanuk's Avatar
Guess LME and I have no clue and I am just luckier then you so far................
I take that back... in all fairness my engine was built with 23lbs maximum boost in mind, considering it is a stock block. ..... for 30lbs there are better options for sure, and a stock block isn't one.
Old Oct 31, 2017 | 12:54 PM
LME is a great company but the OP stated he weighs 3800lbs and wants 1200rwhp. I have been down that exact road. I see you have not with a c6 vette. There is a big difference in weight and horsepower.
The shelf wiseco pistons will get the job done no doubt, I did it for 3 seasons. That piston came at a price though of inspecting it every winter. It is not a reliable unit if you want big power to push a heavy car into the 8s.
The piston I posted is specifically designed with no reliefs because even with a super safe tuneup at 14 degrees of timing and 11.3ish AFR it would still get hot on that edge and lift the ring-land in hole #7.
Old Oct 31, 2017 | 12:59 PM
Realcanuk's Avatar
Wont argue your points... all valid. 11.3 isn't as safe as most think because #7 could be quite a bit leaner. I run on the rich side for that reason.
Old Oct 31, 2017 | 01:46 PM
asubennett's Avatar
I have similar Diamond piston. They are so beefy, that when I switched to an aluminum rod material had to be removed from underneath the dome to clear the big end of the rod.... Insane amounts of material.
Old Oct 31, 2017 | 11:17 PM
Rudy72's Avatar
something like this with Callies Ultra H-Beam Rod!
custom Diamond, coated top and sides are hard anodized, 4.125 bore
