LS9 3 bar MAP on truck intake
Old Oct 26, 2017 | 03:31 PM
Rob07002's Avatar
Default LS9 3 bar MAP on truck intake
I bought the LS9 3bar map sensor. Plan to install where the old MAP sensor goes. The LS9 sensor tube is larger than the truck sensor. Should I just drill it slightly and push in or is there a better way?
Old Oct 27, 2017 | 10:46 AM
Suncc49's Avatar
EFI source makes one that fits plug and play for 35 bucks
Old Oct 28, 2017 | 12:40 AM
Rob07002's Avatar
Yup, sent the other one back and bought the efis one like I should have in the first place.
Old Oct 29, 2017 | 10:06 PM
slocaddy's Avatar
Wish I had known this when I did mine, what a perfect peice
Old Oct 30, 2017 | 02:16 AM
customblackbird's Avatar
Got a link to this sensor?
i did a LS9 sensor in my NNBS intake mainly bc the FItech system is tuned for it.
Old Oct 30, 2017 | 09:51 AM
bigmandengo's Avatar
Mine is installed in the egr plug and a pipe plug is plugging the old hole.
Attached Thumbnails LS9 3 bar MAP on truck intake-img_20160123_165138_zpsquuroowy.jpg
Old Nov 4, 2017 | 02:01 PM
slocaddy's Avatar
Ok, so does anybody know if this is actually a 3 bar zr1 map?? Or is it actually a duramax map? I know the duramax would a direct swap, but is more difficult/dirrerent to tune than an actual zr1 3bar map??
Old Nov 4, 2017 | 02:33 PM
Yes, these are real GM LS9 ZR1 3 bar map sensor.
Old Nov 4, 2017 | 03:14 PM
LS6427's Avatar
This one......will this work in an LS3 intake....?
http://www.tickperformance.com/gm-3-...d-ls9-engines/
Old Nov 4, 2017 | 04:14 PM
3 window's Avatar
I had the one mentioned above from EFI source. Lasted a summer and gave me fits. Changed out for the Holley 5 bar. Nice piece. Accurate and repeatable. There’s a reason it’s $35.
Old Nov 4, 2017 | 04:42 PM
LS6427's Avatar
Will a Holley 5 bar fit into a factory LS3 intake?
Will it be fine and easy to tune for an 18-20psi set up?
Old Nov 4, 2017 | 05:07 PM
3 window's Avatar
I have a vacuum block that I threaded it into.
Old Nov 5, 2017 | 11:44 AM
Rob07002's Avatar
The sensor I had was areal LS9 3 bar map, 12592525. I returned it and bought the EFI Source LS1 style 3 bar, http://www.efisource.com/shop/ls1-st...ar-map-sensor/, and it fit right in the truck intake, stock location.
Old Nov 6, 2017 | 10:11 AM
Did you read the post of 3 window above? #10 I believe.
Personally never used the EFIsource version, but if it doesnt last long then its not a good option. Ive used aftermarket 2 bar maps and they are junk right from the get go, so now I purchase OE Acdelco and they have been good everytime. Sure $50 or so a pop hurts but its better than spending $35 a few times or popping the motor due to an inaccurate sensor.
Old Nov 6, 2017 | 11:23 AM
LS6427's Avatar
So are you using the Holley 5 bar.....or the AC Delco LS9 3 bar map sensor....?
Which one are you saying is working out really well...?
Old Nov 6, 2017 | 12:10 PM
hellbents-10's Avatar
we have an adapter that you can use to install the zr1 map right into the older intakes with an orange grommet.
Old Nov 30, 2017 | 01:45 PM
epfatboy's Avatar
Got a link for that adaptor and are you saying it is for the LS9 map?
