408 s484 missing power over 15# boost
Old Nov 16, 2017 | 08:59 AM
gtistile's Avatar
In for a conclusion on this... I am surprised it taps out so soon if its a backpressure issue. Running that exact turbo on a 9:1 5.3 with 317s I get great gains all the way up to 30psi. It’s not until that 30+ mark that it’s not making much power. 30 is good for 1025whp and 35psi only makes 1088whp. The happy spot on my combo seems to be that 26-28psi range. Just some data points, now I’ll pay attention to what you guys find.
Old Nov 16, 2017 | 09:50 AM
fastbarry's Avatar
Originally Posted by Old Geezer
"br7efs plugs at .027" gap. ". Maybe too much at 25psi?
.022, and see what you have.
What do the plugs look like, after the 25# pull[s]?
What do you have for coil dwell time? That heat sink coil may not be happy, over about 4ms.
3.5 ms dwell at 14.3v
i can crank the dwell up abound 4+ms if you think that may help
Old Nov 16, 2017 | 10:07 AM
Forcefed86's Avatar
Try to tighten the gap to .015. Others have had to go that tight to keep the spark from blowing out. Should rule out the spark blow out theory anyway. Then you can move on to other possibilities.
Old Nov 16, 2017 | 10:51 AM
dburt86's Avatar
Raise the dwell. I run a .025 gap at similar boost and dont have issue at around 1000whp
Stock truck coils and br7's
Old Nov 16, 2017 | 12:08 PM
Forcefed86's Avatar
Seems pretty random with who does/doesn’t have spark issues. Many of the Holley guys with spark issues around the OP’s power level seemed to be able to bypass the issues with a really short gap. It’s worth a shot being free and easy to do anyway. Most don’t gap down far enough to trouble shoot blowout IMO. .015 or smaller to test.
Were you on E85? I think there’s a ton more fuel in the cylinder and you need more spark in general. Also wonder if guys are cooling the ethanol down too much with the bad *** intercoolers. “Cool” ethanol is harder to ignite. I know a few of the guys that race target 150+ degrees because the fuel supposedly burns better. (not saying there’s any merit to it, but it makes sense). Pretty sure Mark F. ran the crappo Ebay IC and had pretty high charge temps.
Old Nov 16, 2017 | 12:22 PM
2JZFC's Avatar
Big difference when it comes to turbo hot side between a 5.3 and 408ci.
Old Nov 16, 2017 | 02:40 PM
DBRODS's Avatar
i just finished a foxbody with SBE 5.3 and S484 with 1.58AR. Made 750whp on 16psi, 11.8afr and 1040whp on 25psi 11.6afr. Compression is 9.6:1 with a 226/235 BTR cam and spinnning 7800rpm. Holley dominator with Br7efs gapped at 0.024 running Metco coils. 4.5ms dwell. Shows no issues of running out anytime soon.
http://pix.sfly.com/_PNf1Zhd
Old Nov 16, 2017 | 03:39 PM
gtistile's Avatar
I agree, I just dont know how much. I’d think the turbo could hang in there till at least low 20s before it started choking out like that tho... or does the added size really change things THAT drastically?
Old Nov 16, 2017 | 04:20 PM
69-chvl's Avatar
Sometimes I wonder if a particular turbo is just f'd-up and doesn't produce like it should.
Is there way to send a turbo off to a place to get tested somehow?
Old Nov 16, 2017 | 04:26 PM
ls3fox's Avatar
7 Second Club
what cam is in it i dont see it listed and was it degree'd
Old Nov 16, 2017 | 04:55 PM
SLOW SEDAN's Avatar
Certainly is, but we’ve gone mid 8’s at high 150’s in a 3700lb car with a 76mm borg and a 408 at much higher boost then the OP is running. Granted Jose said we spun the **** out of it, shaft was blue. It still made 950 through a 400 and 28” tire.
Old Nov 16, 2017 | 09:31 PM
  #32
fastbarry's Avatar
it is a martin smallwood specced cam motion cam. i dont recall exactly the numbers. low 230s at .050" .600 lift with wide lobe sep.
i am at home and all that is at my shop.
Old Nov 16, 2017 | 09:36 PM
  #33
fastbarry's Avatar
i built a 408 primarily for a wide power curve for offroad use and still do 1000 hp.
i find it hard to believe i am over flowing the turbo at this point. i will try to get it back on the dyno this weekend and close the plug gap
Old Jan 4, 2018 | 06:08 PM
  #34
slowlsx's Avatar
What kind of data/power curve are you seeing with that new Holley intake over a hi ram?
Old Jan 15, 2018 | 07:08 PM
  #35
2JZFC's Avatar
Impressive. What fuel?
Old Jan 15, 2018 | 07:39 PM
  #36
brandon6.0's Avatar
Post a pic of setup would help.
What intercoooler u running? Is boost psi gauge plumbed after cooler?
Old Jan 16, 2018 | 06:23 AM
  #37
rkupon1's Avatar
Fwiw, Ablakez28 ran a s484 with a 408. I believe had ls3 heads on home built turbo kit(that i bought). He clicked off 8.85 at 150+mph. I think it was 20-21psi. Prior to that, stock 6.0l n s480 made 888/1004, ran 9.0s
