turbo rebuilders
Old Nov 24, 2017 | 04:04 PM
Taxman20's Avatar
Default turbo rebuilders
Is there a re-builder in Texas that anyone recommends? I had rebuilt my S482 after it failed and leaked a ton of oil. Went with the newer thrust bearing design. Pulled it today with all my oil lines to flush and clean all of the bearing debris from the engine failure and found the turbo is still leaking pretty bad. And it only made 2 passes since the rebuild. Everything inside it looks like new so nothing is really obvious. I think I will let a real shop do it so they can measure everything to be safe.
Old Nov 27, 2017 | 07:32 PM
4EyedTurd1's Avatar
Majestic Turbo in Waco is pretty good close for you.
Old Nov 27, 2017 | 08:03 PM
Taxman20's Avatar
I spoke to 3rd coast in Houston today and they told me to put it back together and try it with the new engine. Due to the insane blow by the engine had they said it most likely caused it not to drain, even with the scavenge pump and allowed it to fill with oil. Made a lot of sense.
Old Nov 27, 2017 | 09:49 PM
Baderic03's Avatar
Smeding diesel. Build and sell and are a dealer for Borg
Old Nov 27, 2017 | 09:50 PM
Baderic03's Avatar
i dont tjink your motor had 30+ psi of blow by and stop the oil from draining.
Old Nov 27, 2017 | 10:09 PM
Taxman20's Avatar
The scavenge pump doesnt push at 30psi. It did the same thing when I first built it and forgot to turn the pump on a couple of times. Filled the exhaust housing to the point of spitting oil from the downpipe. It had enough blow by to completely fill up the catch can and blow oil all over the firewall from the can in 1 6 second pass. So yea, it was bad.
Old Nov 27, 2017 | 10:11 PM
Baderic03's Avatar
I guess so then. I would still have it rebuilt and balanced.
Old Nov 28, 2017 | 04:49 PM
stevieturbo's Avatar
Almost all turbo oiling issues are related to inadequate drain, which can include excessive crankcase pressure.
Try it first, you've little to lose.
Old Nov 28, 2017 | 05:29 PM
Taxman20's Avatar
Agreed Stevie. No sense in spending 400 bucks to rebuild it if its fine. A little oil in the pipe isn't going to hurt anything if it is leaking because Ill check it after a run or 2. Shaft play really feels good to me. As good as it was when I bought it and it wasn't leaking then. And everything in it looks fine.
Old Nov 29, 2017 | 10:44 AM
DBRODS's Avatar
stay as far away from majestic as you can.
Old Nov 30, 2017 | 06:43 PM
Taxman20's Avatar
Edited, wrong company.
Old Nov 30, 2017 | 08:49 PM
4EyedTurd1's Avatar
No ****? Got a link?
Old Dec 1, 2017 | 06:55 AM
Taxman20's Avatar
edited my post. Wrong company. It was Turbo Rick in SA.
