Bummed...Turbo Help Needed!
Old Jul 1, 2004 | 08:50 PM
Earl H's Avatar
Default Bummed...Turbo Help Needed!
Ok, heres the deal. I have a 2003 Z06 with a stock displacement forged motor. I am running a custom single turbo kit using a T76 gts unit. The car currently makes 600rwhp at 12 psi (with a s/c cam and a tune that probably isn't quite there yet).
Now my dillema:
I am currently having a 429 Darton Long Block built. The T76, while rated at 1,100fwhp, wont fit the bill for a big cube motor, due to the "small" turbine and T4 flange. It was recommended that I move up to a T88 for better exhaust flow. After seeing the T88 mid frame turbine housing, I see why. I test fit the turbine housing (thanks Jose) and it fit. Since the T88 and T76 use pretty much the same compressor housing, I was all set and ready to pull the trigger, and order the unit...well not so fast!!! I started thinking (pretty dangerous) and the thought occurred to me that the taller turbine would relocated the centersection and compressor upwards by some amount and the length of the unit would also change the position (forward) of the compressor housing. I ordered a T88 mockup unit form Precision and after recieving it today...I am sorry to say that it won't fit. There is no way, no how (well not w/o putting some big "bubble" in the front passener side of the hood..not).
Is there a turbo that would use the GTS center housing and compressor (well similiar in size and flow). It would have to be the same length and height as the T76 gts unit. I would be willing to change flanges if I can find a unit that will provide the flow that I need. I want to run a 429 at 10 - 12 pounds of boost.
Old Jul 1, 2004 | 09:33 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Call me tomm, I may have a turbo for you. You know I'm knee in these things...lol. I can get you the GT42-76T with T6 housing if you want to try that. We can talk tomm more in detail.
Jose
Old Jul 1, 2004 | 09:34 PM
LS1TECH Sponsor
BTW , don't get to bent out of shape, PTK's twin kit will do the trick....hehe.
Jose
Old Jul 1, 2004 | 10:20 PM
Phil99vette's Avatar
7 Second Club
Since when does PTK offer an LS1 Y-body kit?
Old Jul 1, 2004 | 10:24 PM
LS1TECH Sponsor
They will be offering one hopefully by then end of august.
Jose
Old Jul 2, 2004 | 08:25 AM
MIGHTYMOUSE's Avatar
how come my gt80 gets no love? works for me!
Old Jul 2, 2004 | 09:36 AM
LS1TECH Sponsor
David, I had a GT80R DBB come through, and its a nice turbo. The drawbacks were the price is way up there, and also the R-trim wheel is as heavy as a mid-frame T88 turbine. Consequently, the turbo is kind of lazy. Also on turbomustangs, one of the fellows there went from a GT80R DBB to the 76GTS and the car spooled a good bit quicker even though its a friction bearing turbo. Don't get me wrong its a nice turbo, but for Earl, the GT80 would still be a restriction since its still based on a T4 frame exhaust.
Jose
