Trans Am L33/4l80e/78/75 Build
This is the oil drain length as sent by Huron Speed.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171209_103843_zpsk4e7zwbd.jpeg)
This is after me fixing it.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171209_105114_zpsypx4dae9.jpeg)
Nelson 4l80e harness
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171209_115856_zpssny9qwmq.jpeg)
Pinned the PCM and routed all the wiring on the motor. She is ready to be installed.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171209_124646_zpsklgj0pui.jpeg)
Racetronix fan harness requires you to make new weathpak connectors.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171210_093218_zpsltd4ynkq.jpeg)
Fan wiring done, intercooler, and tubular bumper support mounted.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171210_114313_zpslixalnfh.jpeg)
I cleaned off the excess that would have gotten in the turbo and enough was left on the sealing surface i decided not to. The fit was very good so i made a judgement call.
Didnt take long to hoist it up and set it down.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171213_123955_zpsgbajq9xk.jpeg)
PCV lines made, battery installed, trans dipstick etc etc.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171213_165116_zpsgn4jtgub.jpeg)
random
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171212_204425_zpsuknw2oxs.jpeg)
Used washers, gear oil, and an impact to draw the studs from the inside of the case.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_135237_zpsupukdlgk.jpeg)
Get out of there sucka.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_132206_zps7dbxgtqj.jpeg)
welded a drain and fill plug on
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171214_174816_zpsrifhznlk.jpeg)
quick trip for 20 gallons of fresh corn. Mine needed a top off too.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_125619_zpslrwlgnwh.jpeg)
How'd this little retard escape.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_140521_zps60jdrw86.jpeg)
9 inch housing on the scale
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_133530_zpstipnilxd.jpeg)
Aluminum center section
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_161858_zps8kql8yx9.jpeg)
Mock up for DS measurement
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_163020_zpsnnuisbtw.jpeg)
random
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171215_163200_zpssrty4m3x.jpeg)
Pressed the backing plates/bearings on. Went very smooth.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171218_131151_zpsud0bqtjq.jpeg)
The entire garage is filled with aluminum brake caliper dust. The good news is there is some caliper left.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171218_161521_zpsisa2gpjz.jpeg)
Mounted, done, and at ride height. Rear suspension is also installed and adjusted.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171219_133712_zpswierryie.jpeg)
Waiting on rails for this. Its the fatass model. Everyone who sits in it slides around
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171218_163932_zpshi5dtyd6.jpeg)
Got a pair of these for the back for now. The Decarbons are shot.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171220_132650_zpszrdzwcjw.jpeg)
When the OEM 15 year old shocks wanna spin the shaft instead of come undone you improvise got damn it. More updates soon. Also, did a trans cooler fan power up and man they move some air.
![](http://i275.photobucket.com/albums/jj294/01ssreda4/BlackTA/20171220_140329_zps5g6s7fzu.jpeg)
#32
Based on the measurement Bob at brute speed wanted, my measurement on the car was 44.5". That is not the center to center measurement, thats the trans case to the ujoint flange on the rear.
#33
LS1Tech Sponsor
It's looking good Steve! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
