Twin gt3582 billets on a 5.7?
Old Dec 11, 2017 | 04:37 AM
Cwarta's Avatar
Default Twin gt3582 billets on a 5.7?
Looking for some insight, I can’t find a single result on the billet gt3582 from VS Racing. Looking to run them on a bone stock ls1 trans am for about a month, then do cam and sTall for them. Any ideas what they will perform like? Lag? Max power? Thanks guys
Old Dec 11, 2017 | 10:21 AM
R_trim 93GT's Avatar
How much power are you wanting to make and what compressor housing and turbine housing are you thinking about using?
Old Dec 11, 2017 | 11:10 AM
Cwarta's Avatar
61 compressor mated to a 63 turbine, .82 A.R. T3 is all I can find.
No real goals, just looking for a set that will have decently quick spool up, and won’t choke out a cammed 5.7 once I can it. 600whp would be great, maybe a little room to grow and I’d be tickled.
From qhat ive read on the cast wheel version, it would do all these things beautifully. But I can’t find Anything on billet versions
Old Dec 11, 2017 | 06:00 PM
Cwarta's Avatar
Well Viren said they should be a good fit, I can’t findcresults for them anywhere, or any feedback. So I guess I’ll be the guinea pig
Old Dec 11, 2017 | 10:34 PM
coltboostin's Avatar
Lag- None. You will start to see backpressure issues above 800-850 whp depending on your cam and exhaust. Try to keep it dual 3 all the way, or dual 3 to 4.
Old Dec 12, 2017 | 12:29 AM
Cwarta's Avatar
Excellent, I’d be tickled with insta spool and 600whp, if it has room to grow to 750-800 I’ll be very pleased.
I had plan to run 3” to the old 3” y pipe and then use the 3” exhaust out the back. But I will put a cutout on each pipe where the y merges under the car. Should work?
Old Dec 12, 2017 | 10:24 AM
I agree with what has been posted. 600 to 900rw will be a good efficient range with these turbos. You shouldn't experience any lag. I've found that turbos in this size range with a 5.7 get very responsive around 14 psi and then become real happy around 17 to 18 psi.
Old Dec 12, 2017 | 10:43 AM
Forcefed86's Avatar
I’m on the smaller .63 T3 with the billet 64mm 10 blade compressors on the GT3582. Not sure which compressors VS uses on theirs. But these were $250 each shipped and you had an option on exh. housings. I’d suggest the larger .8X housing option.
My 5.3 (8.9:1 even) lights them off super quick. They are violent little suckers. Had to do all kinds of things to dumb them down on the initial “hit”. Super mild GM “hot cam” (Howards version) and 241 heads. I'd guess it's easily making around 600 crank at 15-16lbs. I run them without an IC as well.
Old Dec 12, 2017 | 12:44 PM
I had a similar experience with the turbonetics using a 62mm exhaust wheel and 0.82 T3 housing on a 5.7. With a manual transmission and no two step, they were fully lit by the 30 foot mark.
Old Dec 12, 2017 | 01:46 PM
Cwarta's Avatar
thanks for the input guys, sounds like they should work great. I’m pretty disappointed in the amount of info VS has on these, they really don’t tell you anything.
all I know is they are .61 compressor and .63 on the turbine, and .082 A.R.
i hope they work well for me
Old Dec 13, 2017 | 10:26 AM
Cwarta's Avatar
Im putting them in a 99 t/a, 80e with stock stall for a few months, until work picks up and I’ll get a good converter. Stock cam for now.
Hoping with the aloppy “transbrake” mod I can make positive pressure on the stock stall.
planning the rev 9 intercooler setup how It’s shown. I suppose I should make a build thread
Old Dec 14, 2017 | 07:43 PM
How long have you been running them? They holding up?
Old Dec 14, 2017 | 07:44 PM
Try and make something bigger than 3inch happen, of get the cut outs. It will make a significant difference.
Old Dec 15, 2017 | 07:41 AM
Forcefed86's Avatar
So far so good, but only 500-600 miles on them. Been cold here, no heater in the car.
Old Jan 24, 2018 | 12:45 AM
Cwarta's Avatar
Just wanted to update this's case anyone searches these in the future.
Stock 80e stall, stock cam, 3.73 gears, I was able to build 1.5# of boost on a 2# WG Spring with 1800 rpm and 2 step foot brake. I'm not sure if that's all it's got or if the gates are opening. These things are going to be nuts.
Old Jan 24, 2018 | 01:47 PM
Forcefed86's Avatar
Good to hear! So was that the .82 housings?
Old Jan 24, 2018 | 05:55 PM
Cwarta's Avatar
Yup! That's the .82's!
Old Jun 13, 2018 | 01:55 PM
Cwarta's Avatar
She’s up and running on the gt3582’s, incredibly happy so far!
Old Jan 19, 2019 | 06:49 PM
Cwarta's Avatar
Update for future people, made 680whp today on 19# @5500 and 10.0 afr, never got to make a full pull due to ripping a wastegate again. I think thinwould have peaked low 700’s on this pull.
19#, 14*, 2# Gate springs with 23# of dome pressure.
Mine are the gt3582 billet wheel with 61/64 and .82 ar, T3.
Old Jan 19, 2019 | 07:06 PM
mightyquickz28's Avatar
How early (RPM wise) were you seeing boost? I have these same turbos.
