Turbo ls1 cam choice???
Old Dec 15, 2017 | 03:16 PM
b20forlife's Avatar
Default Turbo ls1 cam choice???
I have a 98 ls1 engine that is pretty much stock. It has a 7875 turbo setup being built right now. I would like to know what cam you guys recomend? Its not a daily driver but i drive it to work every once in a while. Oh and i am using the stock converter for now till i can buy a new one. Trans is a built 4l60e.Goal is 600whp on pump gas (91). So what cam do you guys recomend with stock converter
Old Dec 15, 2017 | 03:28 PM
sbcgenII's Avatar
Stock cam works fine. I would do converter first.
Old Dec 15, 2017 | 06:32 PM
truckdoug's Avatar
converter.
Old Dec 15, 2017 | 07:01 PM
SLP1998's Avatar
Converter.
with that turbo,you shouldn't have a problem meeting your goals.leave the cam alone.
Old Dec 15, 2017 | 09:04 PM
epfatboy's Avatar
Converter here as well.
But if you must... Sloppy stage 2 Cam
Currently Jegs is the stage 2 recommendation but it's the same as the Elgin E1840P which is about $40 cheaper at $241
You'll want springs with that, either PAC 1218 or PSI 1511's. PAC's can be had for $136
You probably won't need it since above Cam is under a .600 lift but a trunnion upgrade would be a nice. I went with captured needle bearing kit for $92.
Here is a pro tip:
Order it all today, should get it in time for Christmas. Wrap it up and stuff it way at the back of the tree and label it to your self from your wife. When you dig it out and open it make sure you are as excited as can be and make sure to thank her for making it the best Christmas ever.
Old Dec 15, 2017 | 09:35 PM
coltboostin's Avatar
Stock Cam made 870 with a great powerband for me at 24psi.
Rock it
Old Dec 16, 2017 | 06:47 AM
forcd ind's Avatar
Not to get off track, but has anyone ever done a back to back test on the sloppy cam vs the Little John stage 2-I know the LJ is spec. for turbo.
In other words gains vs $$$
Old Dec 16, 2017 | 09:40 AM
Game ova's Avatar
Converter is pretty much mandatory. My vote is Tu1, makes good power and has a smooth idle.
Old Dec 16, 2017 | 10:37 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I guess I have to be that guy. Anytime you FI a large v8, the 4l60 WILL die. Sometimes a 4l80 isn't even enough. Even running a large stall with stock power can toast a 4l60. Forget the cam until you bulletproof your driveline.
Old Dec 16, 2017 | 10:44 PM
JoeNova's Avatar
Restricted User
I'd go TU1 over the 'sloppy S2 cam' (which is just a cheap Elgin cam rebranded as both JEGS and Trick Flow), any day. The 228/230 112 LSA on the Elgin cam is pretty bad for a single turbo setup with a small turbine.
Old Dec 17, 2017 | 05:17 AM
b20forlife's Avatar
I under stand that be best but it’s a Corvette. The 4l80 conversion is ridiculously expensive. I seen many corvettes last with the same rpm stage 5 trans I have.
Old Dec 17, 2017 | 05:18 AM
b20forlife's Avatar
Thanks everyone. Looks like I’ll just save for a torque converter first then.
Old Dec 18, 2017 | 09:49 PM
gametech's Avatar
At the very least add whatever size transcooler you can fit. Higher stalls add more heat. As long as we are talking about a (relatively) lightweight corvette, your transmission may last a little while.
