Dual fuel pump plumbing
Thanks
So two feeds from the fuel cell. Then one outlet to each pump.
i used a check valve on the secondary pump. Not sure it was needed with the Holley pump, but what the heck.
Then a Y of course to the main fuel line.
Ron
Mine takes 3 filters but I Like to be safe.
I may end up with more junk I don't use, but I have a pile of it I just add to, lol.
At least the compression types are re-usable....once the push fit is on, it's on forever til you cut it off. That is an annoyance if you change stuff.
Plus teflon hose is suitable for any fuel you'd ever use, most push fit wont be
On a side note, they don't come apart. You cut the hose off. So, give yourself some nice sweeping bends in your runs of the line to pull some slack in, just in case.......
Thanks guys
Anyway, I gambled on the Y dist. block being at 45 deg angles (should have meas. better) but it wasn't-so scraping the "hardline" idea and just going with push loc Y to pumps. They will allow for the pumps to be parallel to each other. I have now spent more than if I had just bought the Holley 12-1800 pump, less fittings, less leaks, etc., lol.
