Procharger proflow not holding boost! Help
Old Jan 8, 2018 | 06:08 PM
dlandsvZ28's Avatar
Toss the silicone hose clamps you have and invest/replace with stainless t-bolt clamps. A set of 10 for about $20. The clamps you currently have destroy the silicone at each perforation under the band of the clamp.
I would also replace the silicone hose connectors with at least 3 ply. Four ply probably not necessary when running low boost.
When you have the piping apart also check to see if the pipe ends are bead rolled. If not I would have the ends bead rolled. The bead permits a much better seal with the clamp.
CX racing clamps IMO are just as good as more expensive clamps.
https://www.cxracing.com/silicon-hos...se-clamp-clamp
Good luck - looks as if you have found the reason for the diff in boost.
Old Jan 8, 2018 | 06:46 PM
corvet786c's Avatar
OK I will look into those Stainless steel clamps, There is a bead lip on the end of the piping. Yes, This site is valuable and fellow enthusiasts help one another.
Question: So that pin hole on the silicone during idle was bubbling, would that expand alot during boost. It was not cut or sliced just a pin hole when the windex was applied. Would this explain me loosing about 5lbs of boost?
Old Jan 8, 2018 | 06:49 PM
RonSSNova's Avatar
I’ve taken turbo/blower plumbing apart on more than a few customer cars where the clamps were way over tightened and had crushed the alum pipe. Couldn’t see it at a casual glance.
Even took a hose off the throttle body and found the same!
I’d take it all apart and replace any hoses that are flimsy. Inspect the metal tubing and as was mentioned, get rid of the hose clamps.
Ron
Old Jan 8, 2018 | 07:01 PM
ddnspider's Avatar
No a pinhole leak or even a few of them will not account for 5psi of boost loss. The MAF coupler is a good place to look like you said. Years ago the instruction manual on the STS turbo kits instructed the installer to drill 2 holes in the bottom of the FMIC to allow condensation to come out...that's 2 leaks in the cold side and it's effect on boost was negligible.
Old Jan 8, 2018 | 07:07 PM
corvet786c's Avatar
The reason for me asking was that the rubber hose coming from the I/C was soft and flimsy and bubbling at idle, from the windex test, it seemed like an old piece. I also had bubbling coming from the MAF, which is better now.
Old Jan 8, 2018 | 08:30 PM
Forcefed86's Avatar
Small pinhole leaks aren't going to hurt much. If you think you are missing lbs of boost... it's a big leak. Fixing 20 pin holes won't even give you another lb of boost. Have you calculated your impeller speeds and ensured you don't have belt slip? Did U cap the BOV yet?
Old Jan 8, 2018 | 08:35 PM
corvet786c's Avatar
No I have not, what do you mean by capping the Blow off valve?
Old Jan 8, 2018 | 08:43 PM
Forcefed86's Avatar
Block it off in some way so it can't be opening durring a pull. Large rubber cap and a hose clamp comes to mind. What kind of BOV is it? is the top adjustable?
Old Jan 8, 2018 | 08:44 PM
corvet786c's Avatar
Its the older procharge proflow.
Old Jan 8, 2018 | 08:46 PM
Forcefed86's Avatar
Yea so rubber cap and a hose clamp would work fine. Can bench test it as well and see if it leaks.
Old Jan 8, 2018 | 08:47 PM
corvet786c's Avatar
OK Thanks I will look into it. actuall I seen that video and in the comments section someone described that this was not a valid test and posted another link from procharger why there is a gap in this unit to keep the butterfly from getting stuck. That's why there is a gap in the butterfly, but they stated that there is not a substantial leak.
Old Jan 8, 2018 | 09:01 PM
  #32
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I'd be interested in knowing what CFM was lost in that "test".
As for your issue, is it possible that there is frozen condensation or debris keeping the valve from fully closing?
Old Jan 8, 2018 | 09:04 PM
  #33
ddnspider's Avatar
It has to vent some air at idle otherwise the pressure will back up to the blower and put more strain on the bearings at idle. I've seen the same thing on my car. With that said, I pulled the bypass valve and capped the opening in the cold side....made a pull and it didn't change boost but in my instance I was fighting belt slip.
Old Jan 8, 2018 | 09:15 PM
  #34
corvet786c's Avatar
I did take it apart and inspect it, it was dusty but the spring looks new. The plastic on top was intact. I put it back together still has proper vaccum and holds pressure.
Old Jan 9, 2018 | 10:24 AM
  #35
Forcefed86's Avatar
I didn’t even watch the video. I was suggesting you cap it and add shop air to one side to see if it holds air tight or leaks everywhere. It’s a valve that should be open or closed. Pretty simple concept, people over complicate it.
Not saying that’s the problem but it should be a 5-10 minute test to cap the BOV and go make a pass and see if your boost level went up. Those valve types are notorious for leaking.
Old Jan 9, 2018 | 07:07 PM
  #36
stevieturbo's Avatar
Not a damn thing wrong with those hose clamps. More often than not, t-bolt clamps where they are not needed, just result in users overtightening things and making things worse...and that's with good quality t-bolts.
Some of the ones out there are pure ***** instead ! lol
A good quality worm drive clamp will easily hold more boost than the user is talking about
Old Jan 9, 2018 | 07:57 PM
  #37
corvet786c's Avatar
So my clamps are ok then, the ones in the photo?
Old Jan 9, 2018 | 08:00 PM
  #38
jimmyg's Avatar
What's a d1sc supposed to put out for boost with a 4.38 pulley?
Old Jan 9, 2018 | 08:04 PM
  #39
ddnspider's Avatar
That's why I was surprised when he listed all the mods....a pulley that big still making 10psi seems surprising to me.
Old Jan 9, 2018 | 08:11 PM
  #40
corvet786c's Avatar
My guage is reading about 10lbs in 60 degree weather.
Mods Forged LS6 with D1SC blower and blower cam, ported 243 stage III patriot heads, Fast 102 7.5in crank pulley 4.38 blower pulley 1 3/4 headers with 3.42 gears. The car was suppositdly built right by a performance shop. A millionaire owned the car but did not take care of it here in south fla. The car needed alot of refreshing, now after this leak is fixed will run like a beast. It was tuned by a shop in Boca raton too.
