Procharger proflow not holding boost! Help
On a side note when the tranny gets lock in 4th it seems to kind of shifts hard, I don't like how it shift just in 4th. The tranny fluid has been changed and the previous owner said that this tranny is pro built he spent 4 grand to have it built up. Any thoughts?
3.42 gears seem pretty tall too. Since boost is RPM based, I’d think you’d want more gear in it? Then once you spin the blower spinning faster, belt slip rears its ugly head. Good luck with it. I’ve had nothing but problems with them. The F1 is the unit I’d be looking at!
Now showing more that 5 lbs more like 7 where its supposed to be. The car absolutly rips now. Any other suggestions
Thank You all for your help and comments well appreciated.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Ok here's the story, yesterday I was hitting about 7.5 lbs of boost after tightening the adjustment nut on the procharger bracket, its in the middle section on the same belt that I had on about 6 months now, its broken in. Its a gates greenback 060930HD, the ribs look good on the inside, but you can tell it was stretched on the green part, well today I go wideopen throttle on the street and the boost is not holding again, it dropped off just after 5lbs, so I think I am slipping again up top, should I just go ahead and buy a new belt. I liked the micro v 060930. Does it matter should the current belt still hold or has it lost its rigidity. Thoughts
Also when the car locks up in 4th, its smoother but there is still some flex slight shaking even thought the belt is tight now on the crank. When I had the micro v belt the shift in 4th was clean and smooth. It just seems like this current belt is rubbery, does this make sense, anyone know what I am talking about. Whereas when I had the micro v belt it was not so rubbery but more solid. I don't know how else to explain it.
Would it make a difference to buy another belt vs the one I have on now? This is on a 6 rib setup.
Back in the day (2005 or so) the six rib pulley's slipped a lot. As a result ATI came out with an 8 rib pulley along with a way to pin the pulley to the crankshaft . Key it in a sense with a roll pin to keep the pulley from slipping on the crankshaft.
That said, even the 8 rib belts slip when going over 8 lbs or so.
Bob has the pinning kit as a loaner I think.
Whew - that's a long belt - 93 or so inches - sure that's the right number?
Gates numbers are usually K060930 - with the 6 meaning it's a 6 rib.
