need help! ? about Hobb switch Urgent!
Old Jul 3, 2004 | 12:30 PM
ss2000ls1's Avatar
Default need help! ? about Hobb switch Urgent!
Im installing powerdyne SC and i dont know how to hook up the hobb switch. It looks like it uses a vaccum hose, but a vaccum hose did not come with the kit and doesnt give any instructions to how to hook it up except for the wiring diagram. I try to call powerdyne but they are closed. this is last thing i have to do before im done. I would be much apprecciated 4 any help. Thank you
Old Jul 3, 2004 | 01:11 PM
frcefed98's Avatar
Unless they changed the kit since I owned one......it should be like this, there should be a "tee" that was spliced into the brake booster line. One vacuum line goes to the FMU and the other goes to the hobbs switch which then goes to the bypass valve(gets split again with a smaller tee)
Thats the way it was for my PD back in the day, if you need more vacuum line go buy some more.
J
