Trunk mounted meth reservoir/pump issues
If a check valve closes under vacuum what keeps it from closing when being pushed from behind by meth/water? Snow recommends and includes their upgraded solenoid with their trunk mount kit with longer lines...there has to be a reason for this.
And those asking how a check valve can stop either of the above......need to google what a check valve is.
Clearly it isnt an open pipe !
But yes a solenoid is another option.
And ideally either the check valve or solenoid if they are actually needed would be located as close to the nozzle as possible.
It’s also suggested not to inject behind the TB as the vac signal will be much stronger there. If you do, you’ll need a healthier spring to hold the valve closed. (or a solenoid) I’ve run a ton of remote mount systems. A check valve at the nozzle located pre-TB has never given me an issue. I setup a few post TB and needed a stronger spring in the check valve to prevent siphoning.
I will be injecting after intercooler before iat sensor before throttle body. Car is procharged.
All that’s going to do is saturate the sensor bulb, which will then report false cool readings. This will make many think they are running intake temps much cooler than they actually are. Which makes it more likely you’ll tune incorrectly and break something.
On the other hand it does let you know the water/meth is active. So it can be setup as a sort of failsafe if you have that ability. Just be educated enough to realize those super low reported charge temps are false data.
