416 thoughts.
Old Feb 20, 2018 | 05:57 AM
yenkomike's Avatar
Default 416 thoughts.
got a chance to pick up a 416 shortblock ls3 block with all forged internals . thinking about throwing in a 220r cam I have and a set of 317s and see how she runs. I don't think my 83 mm turbine will get it done but that I can change.only real reason is the 100 lbs off the nose.
Old Feb 20, 2018 | 06:36 AM
ls3fox's Avatar
7 Second Club
if you can get a great deal on it why not I'd go with a custom cam over a 220r and a 96mm upgrade
Old Feb 20, 2018 | 07:05 AM
svslow's Avatar
That thing thing would make some killer torque with a little cam like that.
Old Feb 20, 2018 | 10:16 AM
Bad Apache's Avatar
You already can't hook up that animal. More is better!
Old Feb 20, 2018 | 11:27 AM
yenkomike's Avatar
less front end weight should help? LOL.
Old Feb 20, 2018 | 11:28 AM
Bad Apache's Avatar
My kinda reasoning right there!
Old Feb 20, 2018 | 08:34 PM
47ford's Avatar
What all is needed to upgrade the turbo to the 96?
Old Feb 21, 2018 | 12:44 PM
3 window's Avatar
Right.........the 100 lbs off the nose! Lol
Old Feb 21, 2018 | 12:54 PM
roastin240's Avatar
A different turbo.
Old Feb 21, 2018 | 07:40 PM
yenkomike's Avatar
still on the fence here . to make a 416 work I need to change just about everything to get a decent matched setup.not sure it is worth it. not to mention there is more in the car the way it sets.
Old Feb 22, 2018 | 12:08 AM
3 window's Avatar
I feel the EXACT same way with mine. An engine change typically means a lot of other things need to change as well.
Old Feb 22, 2018 | 05:13 AM
yenkomike's Avatar
if I can get my car to et like it mph's id be good. I feel my 113-114 mph 1/8 mile should go in the 6.0 5.9 range and 141+ mph should be mid to low 9's .
Old Feb 22, 2018 | 10:00 AM
3 window's Avatar
Maybe throw it on a trailer and take it to a good track. I know you say Lapeer is lacking when it comes to surface prep. I think your goals are attainable for sure.
Old Feb 22, 2018 | 12:38 PM
yenkomike's Avatar
yes I can get more at a better track. but it is built to run at my local track. I really am very happy with the car. there are a few 9 sec small tire cars but none that are true street car's let alone slapper bar cars.
it is hard to touch anything when all it needs is an oil change in the spring and it will go 9's. and I can drive it to work.
Old Feb 22, 2018 | 12:55 PM
MY_2K_Z's Avatar
I'd find another use for the 416. You seem to have the current configuration sorted out so why not just enjoy it and find another project for the 416.
Old Feb 22, 2018 | 05:42 PM
ls3fox's Avatar
7 Second Club
yes like donate it too me lol but honestly it sounds like your pretty close to where you wanna be with the car already just a few tweaks away
