Small truck cross over using cast manifold.
just working on my turbo build. A 2005 gmc canyon with a 6.0 ltr motor. I am tight for space so I thought using a cast manifold flipped over might be the ticket. I never thought about connecting the cross over.
attached are some pics of my cast manifold. With me running a 2.25 pipe into the bottom of the number 8 exhaust port.....what are some concerns or issues I have doing the turbo manifold this way.
Any constructive comments or suggestions would be great.
Thanks Ryan
Keep on going, looks good man. I would run 2.125 or 2.25 for the cross over if you can fit it.
Just merge the factory collector down to 2" and run a 2" pipe all the way to the turbo flange. Use a divided T4 and run the other bank in 2" as well.
Use a cheapie 38mm ebay gate on each side. Makes for an easy cheap install with great response and boost control.
not sure what plug you are referring to. The bung you see on the down pipe is for my afr sensor. My o2 sensors are both in their factory positions.
Ryan
Ryan
all in all I'm pretty happy with how it turned out.
