holley mid rise fitment
Old Mar 6, 2018 | 07:00 PM
jordoza's Avatar
Any stage 2 or maybe 3 turbo cam from one of the common guys (ljms, tick or btr) would be best in my opinion. You dont wanna go crazy with the cam. Atleast that is my opinion.
Old Mar 6, 2018 | 07:04 PM
lsxTAlemy's Avatar
Originally Posted by jordoza
I have the high ram on my 2012 camaro and everyone said dont do it cause it gives up so much torque but i wanted that look so i bought it. Maybe im stupid but it looks awesome. I wanted to see how.much of a difference it made in feel of the car so i swapped back and forth from the high ram to the ls3 intake 3 times and never felt the difference under boost. Did it make more power on the dyno with the high ram. yes marginally and it made more torque and the same hp to 5400rpm with the ls3 intake but with either intake off the dyno i never felt it one way or the other. Not an apples to apples comparison just my opinion. No disrespect to anyones views here. Just throwing out my experience.
Thanks for the info. And every set up is different and they all make different powers with similar and different combos. First time boosting so not too familiar with this stuff.
Old Mar 6, 2018 | 07:15 PM
lsxTAlemy's Avatar
Ok can you tell me why? I have ran nitrous and na never boost. And I’m sorry but I love that thing to chop I know it may sound stupid but I like choppy ldle I’m cuerrently running the comp 233/239 @50 113 lsa cam for my nitrous motor wanted something g similar or bigger
I have a buddy running a big na Cam in his but only putting down 700. I’d like for the cam be more efficient on boost but still have a nice chop.
What can I hurt going such big of cam like the stage 4 btr local shop recomended the stage 4
Old Mar 6, 2018 | 07:35 PM
jordoza's Avatar
I had the tick stage 2 and it had a nice chop. Going with to much overlap causes backpressure issues. Even with the 96mm turbine in the s480 i wouldnt go bigger then a stage 2 but guys get away with a stage 3. My stage 3 that i have currently has 6 degrees of overlap and was speced for twin 75mm turbines. When i ran a single s480 96mm t4 tick recommended the stage 2 turbo cam. Honestly i believe most chop you hear on intagram or youtube is more tune related. I can make a stock cam chop with idle correction timing adjustments. I can also make the.tick stage 2 turbo cam sound nearly stock after alot of idle airflow adjusting. Chop is tune related until you go really big cam in my opinion.
Old Mar 6, 2018 | 08:20 PM
lsxTAlemy's Avatar
Thanks bud I appreciate it..and yes you are right on the idle and tuning my tuner usually get it where I want..
Old Mar 7, 2018 | 06:43 AM
stevieturbo's Avatar
Originally Posted by lsxTAlemy
also I'm using the holley mid ram efi, not the sniper low profile one. i know the sniper intake is junk and its only a show piece. its sheet metal and it doesn't hold the boost pressure. is the mid ram the same junk and the sniper ?
You're rather mis-informed.
They're both **** but either will hold boost pressure....certainly no trouble for either for only 700hp though.
Obviously they're different...but both largely junk, although at least the Sniper will see more power over 6500rpm if you'll be using that.
But they can look nice.
Old Mar 7, 2018 | 06:45 AM
big cams can lose power, spool slower and offer a narrower power band so to speak.
They can turn a great powerful car with a wide spread of car into a piece of ****. Now obviously you have the fact it's a large V8 to compensate, but the effects are still there.
Big cams have nothing to offer a street car.
Old Mar 7, 2018 | 09:07 AM
lsxTAlemy's Avatar
Like jordoza said that chop is more of and idle tunning issue. I’ve been looking in to the btr stage 2 and 3 i don’t want something sluggish. Id want something to spool me up quick and get me going. I’m also not sure what merge piping to run with the truck manifolds. I have been doing reading and it looks like you don’t need more than 2.25 my max power goal 1100. And about 700 detuned..
Old Mar 7, 2018 | 09:12 AM
JoeNova's Avatar
Restricted User
Your car is going to be LAZY with a BTR Stage 4.
Old Mar 7, 2018 | 09:53 AM
lsxTAlemy's Avatar
Definately not what I want something to spool up quickly not lasy or laggy.
Old Mar 7, 2018 | 10:13 AM
lsxTAlemy's Avatar
What are you guys suggestions on the cam? Something with a nice power curve and suitable for my power level. I was thinking of giving btr a call and tell them my setup see what they come up with.
Old Mar 7, 2018 | 10:25 AM
  #32
jordoza's Avatar
Getting a custom cam speced is always your best option. I say iom running a stage 3 but its really not the off the shelf stage 3 its a custom speced cam. It makes a world of difference. I have honestly done it wrong twice before i called and had a speced cam. I did the way to big na cam and it sucked. Spooled like crap and was lazy as hell. Then i did the ls9 cam and it was ok but never did make the power i expected and it didnt spool for **** either. So i called tick and got the stage 2 and it absolutely was night and day difference. Spooled 6 to 700 rpm sooner and wasnt lazy out of boost. I will never try the holy grail factory cam or the it will work ok cam again. Get the right cam for your intended use speced by someone who knows what they are talking about and you wont be disappointed.
Old Mar 7, 2018 | 11:32 AM
  #33
lsxTAlemy's Avatar
I was looking for a good off shelf that would work and be efficient with my set up without paying the extra cash of the custom grind.
Old Mar 7, 2018 | 11:41 AM
  #34
jordoza's Avatar
Ok which s480 do you have, also any odea on head flow. Im pretty sure the tick stage 2 turbo cam would do you good but i dont wanna seem like a tick nut swinger so any stage 2 should work from ljms, tick or btr. They are all close to the same. Tick seems to add a little more lift to the brew but i dont think its helpful unless you got ported heads.
Old Mar 7, 2018 | 11:47 AM
  #35
jordoza's Avatar
With all the turbo cams id err on the small side then go to big. The advane ground into the cam makes the biggest difference in spool time from what ive learned. Thats what they mean by 115 +5. The plus 5 is the advance ground into the cam. It helps spool the turbo faster.
Old Mar 7, 2018 | 12:10 PM
  #36
That would make more sense than an inexperienced choice, and that doesnt mean you need a custom cam. There a undoubtedly hundreds of cams available already that will fit your needs.
Old Mar 7, 2018 | 12:15 PM
  #37
lsxTAlemy's Avatar
new selections vs old
@.050 228/228, LIft is .571/.571, and is on a 112LSA.
@.050 226/231 .605"/.598" 113+4
@.050 230/235 .609"/.610" 114+4
old big choices
@.050 234/239 .612"/.610" 115+5
388+ Cubic Inch Turbo Cam has no info on cam specs ..
Old Mar 7, 2018 | 12:49 PM
  #38
lsxTAlemy's Avatar
its an lq4 with 243 hand ported heads by reputable local shop milled 10 thousands . i honestly don't know the flow rate. the s480 is my guess of what the turbo is by looking up the numbers on the cold side 060 and says Borgwarner . its an 80mm but the exhaust housing was changed from t6 to t4 supposedly for quicker spool. i cant seem to get any info on sizing. this thing was on my boys turbo car with the na cam in it. that explains why he wasn't able to spool it up quickly. he now has a precision ball bearing that spools on the dime tho.
Old Mar 7, 2018 | 01:20 PM
  #39
jordoza's Avatar
Pull the turbine housing off and measure the turbine wheel. Turbine wheel diameter will derectly effect which cam will be best for you.
Old Mar 7, 2018 | 01:24 PM
  #40
jordoza's Avatar
The s480 can have 4 different turbine wheels all the way from a 83x75 to the 96mm.
