need advice please with this setup
Old Mar 6, 2018 | 09:07 AM
nick67's Avatar
Default need advice please with this setup
hi everyone,not much of a poster do a lot of lurking and searching but could find anything about this with a definitive answer.
im doing this lq4 wit a s475 twin scroll and was wondering if my 50mm wasegate placement and size would be able to control boost properly.
do i need another? or should i join the other hotside?
Old Mar 6, 2018 | 09:15 AM
JoeNova's Avatar
Restricted User
If you want proper boost control, you have to gate both banks, not just 1.
Old Mar 6, 2018 | 09:22 AM
nick67's Avatar
i figured that,should i get another gate or will the one 50mm handle both?
Old Mar 6, 2018 | 09:25 AM
JoeNova's Avatar
Restricted User
50mm will handle both.
Old Mar 7, 2018 | 02:11 PM
Lsxford's Avatar
On my setup 44mm gate on only 1 bank. I have had it on 2.5 psi with no creep issues at all, its an lq4 with on3 7875. So only venting 1 bank will work for most, YRMV.
However if i were you i simply add another pipe to the other bank and Y it in. Seems like that would be the best option for you and should nearly guarantee smooth boost control
Old Mar 7, 2018 | 02:21 PM
nick67's Avatar
thank you for the response i will "y" it in so i have nothing else to worry about
Old Mar 7, 2018 | 02:22 PM
nick67's Avatar
thanks for your help
