Vortech down on power
Old Mar 13, 2018 | 01:32 PM
Ant-man's Avatar
Default Vortech down on power
LS2/317 heads with a mild NA cam.
Strapped a si blower on and made 690 on 93 and meth @ 12psi.
Broke a PAC spring and bent a valve which kissed the piston, opened up and cleaned everything up with no signs of exponential damage other than a dent in the piston. We said screw it and put it back together after sanding down the piston. Compression check after was 160-180.
Swapped the cam out for a CCP jam cam and pullied down for giggles on E85, the result was 640hp. Checked for boost leaks even though makes 18psi at the manifold. Misfired a little, replaced the plugs which fixed that. Drives strong.
AFR was solid, 16* peak on both runs. Kind of at a loss here, going to build the motor but still trying to find ideas to see if it's anything other than a hurt motor.
Old Mar 13, 2018 | 04:43 PM
jrtoffroad's Avatar
What's the cam specs before and after? Do you have enough valve spring for 18lbs?
Just an FYI, but you might want to try a bit more advance with the E85.
Old Mar 13, 2018 | 08:11 PM
Ant-man's Avatar
E85 is just there because I'm tuned for flex fuel now.
I have brand new valvetrain all BTR stuff the PAC dual spring is what broke before so we replaced everything anyways.
Jam cam: 230/242 .608"/.615" 115+4
