Air Filter for Turbo?
If the elbow is directly onto the intake of the turbo/supercharger then absolutely it will not help straighten any airflow. It will have an adverse effect.
Perhaps if it was large enough relative to the inducer it might not matter so much but I suspect that isnt the case.
if you took Steve Morris' Provolute as an example of an ideal inlet path for a blower or turbo....the full shrouding a 90 deg elbow would add to the front of the unit has to be almost the complete polar opposite of a provolute and worst case scenario.
So being very basic....the outer tip of the inducer ( and indeed the entire half opposite ) has to draw air from across the the side closed to the air inlet. That cant ever be good.
Whereas with a bellmouth or open, or even a pipe...it can draw air more evenly from a larger source.
The first turbo Subarus came with a turbo with a 90deg elbow built in, the old TD05 they used was a pretty good unit for early 90's
But always hampered by that elbow ( well in those cases it was the cast elbow on the turbo itself...then they fitted another plastic elbow before a calming chamber...and then another elbow before the airflow meter lol
Simple mod was to cut it off and take a straight pipe out through the inlet manifold and to a filter. Inlet tract was still not great as it was small and it still needed at least one elbow but much further away from the turbo inlet
But what was once a 3-320bhp turbo max would now make 350+ quite easily and spool faster.
I guess I could leave the elbow and only have the filter pulled, but seems kinda dumb LOL. I get what you're saying, but its about as close as back to back data as I can get. I think its a 4" elbow off the inlet, but would need to do some digging to confirm on the D1SC.
On the plus side between my tuning and the cold air, the car picked up 3mph. Friend got a couple vids including an in-car when I drove by him. They're freaking huge file sizes though so I need to figure out how to get them in a size I can upload. Worst case I'll play it on my laptop and record it with my phone and upload that this weekend.
Only got 3 runs in in like 4 hours cause everybody knew the weather was cold and showed up. Some idiot grudge car decided to oil the track down too and went the ENTIRE length of the track.
https://www.instagram.com/p/BgkGYBjB...levictoryfabco
I'm the left lane. In car is a Gen 4- 5.3, Triple 15, Huronspeed turbo kit with a 78/75mm.
We're going to turn the boost up some more and when he gets another DD this one will get more serious.
I will say I was pretty impressed cause it took forever waiting in line to get into the track and both car drove there, sat in line idling at about 185*, made some passes, and drove home. 93 octane only cars. Yeah not the fastest....but they live to drive another day. #streetcars.
