Air Filter for Turbo?
Old Mar 22, 2018 | 11:14 AM
  #81
rotary1307cc's Avatar
This place is pathetic anymore
If you honestly think a damn turbo guard/screen has the potential to offer less restriction vs a proper filter
Or can't can't grasp how a filter can actually promote flow into an open tube...
U should go back to school
Old Mar 22, 2018 | 11:17 AM
  #82
Glad to have found the filter guys are running that are a restriction
Old Mar 22, 2018 | 12:03 PM
  #83
kingtal0n's Avatar
I may come up with an idea while considering a problem. If I've done or tried something I always post it and its usually easy to replicate, and that one doesn't sound easy so it wouldn't be something I would normally try. Still worth mentioning the idea though. Can you imagine smoke at high frame rate entering a compressor with and without an air straightening device? It may reveal 'lines' of turbulence. How they do something similar with cars in a wind tunnel to find 'lines of turbulence' is what gave me the idea. The turbo manufacturer undoubtedly has a better mathematical approach to this problem and it clearly reflects the front of their housings.
If I've done or tried something I always post it for ex. when I did my balancer for the first time, I had never seen one of these torque to angle or whatever, so I made it into something I could post
Another
Pretty easy to replicate that at home. I posted a whole bunch of those in a thread somewhere...
king talen with a classic autism spectrum word vomit pile
we got some people talking about putting sensors in and taking measurements
thats me. You got me in there twice. I mentioned sensors and a poppet from Ebay twice on this thread. I always do when filters and pcv comes up because the air filter restriction is a key part of a functional PCV system at wide open throttle.
Illustration:
Old Mar 22, 2018 | 12:21 PM
  #84
Game ova's Avatar
Another
Illustration:
Dude....enough with the Pythagorean theorem type responses. Where is your California emissions test passing, AC retaining, full interior, rear exit exhaust having, 7 second car at? Seems with as much as you know, you would be holding court at any track on the planet. Yet, I never see you posting up any track vids. Tell us what your track game is like!
Old Mar 22, 2018 | 12:38 PM
  #85
dlandsvZ28's Avatar
Anger management 101 teaches the rule to never let a discussion turn into a competition because as soon as it does everyone in the discussion thinks they have to be the winner. Ultimately everyone ends up being a loser or worse.
So best when it turns into a competition is to walk away before it gets ugly.
  #86
truckdoug's Avatar
They teach you all that at dirt farmer school?
Old Mar 22, 2018 | 01:08 PM
  #87
ddnspider's Avatar
Originally Posted by Game ova
... Tell us what your track game is like!
He has none. His 5.3 is running literally 3psi of boost and he cares about his MPG at WOT.....
Old Mar 22, 2018 | 01:20 PM
  #88
truckdoug's Avatar
Or hang out while it gets hilarious.
Old Mar 22, 2018 | 01:53 PM
  #89
Forcefed86's Avatar
I agree with the farmer. All about Filter media per sq inch... Much better off with even a small filter.
Screens are horrible for flow and filtration. The new filter guard "MAX" design uses that huge honey comb design because the old screens were so bad flow wise. The filtration is even worse with the new design. Now they are only are only good to keep large rocks and small animals out of the inlets.
It's funny those turbo guard guys tried to implement a foam filter media over their screens a few years back. They were so restrictive you couldn't even get into boost with one in place... so they dropped the product.
Old Mar 22, 2018 | 02:20 PM
  #90
truckdoug's Avatar
Haha that's awesome I'm just gonna zip tie a red scotchbrite pad to my inlet.
Old Mar 22, 2018 | 03:24 PM
  #91
Black_Sunshine_99's Avatar
this has turned into one of the better threads in recent memory. we got it all.
the classic rotarty "just stop posting" like it's 2006 and he's a mod on 4 chan
A+ would read again
Best. Response. Ever.
Old Mar 22, 2018 | 03:27 PM
  #92
A friend of mine ran the foam Turbo Guards...until his turbos ate them.
Old Mar 22, 2018 | 04:51 PM
  #93
ddnspider's Avatar
I'm planning on hitting the track tomorrow. If I can get in more than like 2 passes I plan on pulling the filter on a pass so I can compare at least MPH. If I get to do it I will report back good or bad.
Old Mar 22, 2018 | 05:26 PM
  #94
roastin240's Avatar
Another
Illustration:
I have a Master of Science in Mechanical Engineering and design engines and fuel systems for a living, and I am now dumber having seen this.
lol
Old Mar 22, 2018 | 05:46 PM
  #95
ddnspider's Avatar
lol
Old Mar 22, 2018 | 06:48 PM
  #96
truckdoug's Avatar
Old Mar 22, 2018 | 07:02 PM
  #97
ddnspider's Avatar
yessssssssss!!!!
Old Mar 22, 2018 | 07:36 PM
  #98
70c10's Avatar
I definitely got more from this thread then I asked for hahaha. I have one more question. Is it possible or likely that switching to a bigger/better flowing filter could create more boost?
Old Mar 22, 2018 | 07:45 PM
  #99
kingtal0n's Avatar
lol
Then shame on you. I have a master of science as well, and still going for what comes next.
Maybe you should take a closer look instead of acting like a jackass online in front of your pals
Or option B: Try actually finding something wrong with the illustration. It is easy to say something is wrong... but when that thing is actually correct... you will be unable to find any flaws.
Old Mar 22, 2018 | 07:57 PM
  #100
kingtal0n's Avatar
And now to compile supporting data regarding oil ring tension and engine crankcase vacuum
To get the best results from a pump, you need very low tension rings AND VERTICAL GAS PORTS- With those features, I see over 50 HP gains from conventional rings without gas ports. I have seen where the vac pump installed on a conventional engine will only make two or three more HP than without it
http://www.yellowbullet.com/forum/sh...7&postcount=11
Ultra low oil ring assembly is typically in the 4# range.
Just adding a vacuum pump on an engine with standard tension rings won't result in much, if any, measureable horsepower. A vacuum pump used on an engine with low tension rings will "allow" the engine to produce additional horsepower, benefitting from reduced friction, by controlling crankcase conditions.
Low tension compression rings are only effective when used with gas ports and the vertical port is the most direct and the most effective method of introducing combustion pressure to the backside of the ring groove.
