JGS 50mm springs
JGS 50mm springs
My WG has the large spring now, I think its in the 7 PSI range from what I have heard-in the box was a smaller one, stronger, but when I tried to install it, it wont fit over the nipple. I suspect it may be the wrong spring, WG was new, but bought it off someone. I will be running a boost line to the top fitting, thru a controller. Should the spring fit over that nipple, only way I can see to hold it in place.
