Boosted 5.3 Options
Old Mar 22, 2018 | 12:34 PM
Teddy-2000RS's Avatar
Originally Posted by KingBoo
We'll get new piping and the engine itself doesn't need to be cleaned up or restored other than resurfacing the heads but we just sent it off to our local machine shop for a hot wash
"New piping"? Things might have changed but I do not believe there's an off the shelf kit that's directly useable with a LSX turbo fox. At a minimum you're going to have to fabricate a cold side, whether you start from a universal kit or from scratch is up to your relative skill level. I'm sure by now there's aftermarket hot sides available.
Old Mar 22, 2018 | 12:38 PM
KingBoo's Avatar
If it’s on E85 I'd go straight to 210lb Bosch CNG injectors. 80’s won’t go very far without a ton of pressure. They aren’t much more than the 80’s at $384 shipped. (ebay)
Would it matter if I went pump gas or e85? With my cr
Old Mar 22, 2018 | 01:23 PM
Forcefed86's Avatar
Yup, much harder to make 750+ with that budget on pump gas. Injectors are basically the same price. Just need enough pump to support the injectors on E85.
Have you considered nitrous? A simple cam, intake, exhaust 5.3 with a 200 shot is pretty darn fun. MUCH easier too. You could even run some serious compression if you stuck with E85.
JoeNova's Avatar
Restricted User
On3 has had an LSX fox kit for sale for a LONG time now.
Old Mar 22, 2018 | 03:52 PM
You are correct.
