Torquer v2 with boost?
Old Apr 4, 2018 | 07:29 PM
Big bird55's Avatar
Default Torquer v2 with boost?
So after my last thread i have been leaning to the torquestorm kit.
Would the v2 on the 112 lsa that i have be ok with the blower. I had planned on getting some stage 1 prc 243s milled 20 to 30 and putting them on the lq4.
i plan on getting the btr intake once it is released either way.
or should i just get a plate kit with the heads.
Which way would you lean to.
i tend to lean away from nitrous because it cost more in the end.
Old Apr 4, 2018 | 07:42 PM
HCI2000SS's Avatar
I'm sure it would be fine on low boost, but I bet you'd be faster slapping on a 100-150 shot
Old Apr 4, 2018 | 08:20 PM
Big bird55's Avatar
Thats what i believe as well. But wouldnt the nitrous be a bit harsher on the motor? Was thinking of trying to get 12 to 16lbs out of the blower
Old Apr 4, 2018 | 08:23 PM
HCI2000SS's Avatar
I don't think that cam will work well with that much boost. In your application a 100-150 shot would be less stress overall, unless you go through tons of bottles
Old Apr 12, 2018 | 08:10 AM
Big bird55's Avatar
i daily it just coming from spraying a 383 strocker s10 in high school with to much nitrous i am still kinda burned out on it. but it is looking more what i need to do since only a few have given good advice plus i keep seeing that the torquer 2 responds well to the nitrous.
i just had wanted to try something different than the others .
Old Apr 22, 2018 | 07:05 PM
MUSTANGBRKR02's Avatar
I ran the V2 in both N2O and a turbo and both worked well but not optimum. The turbo setup was small so it ran out of steam quick. The nitrous just kept pulling.
