lsx 376 injectors
Old Apr 22, 2018 | 08:08 PM
Stevef100's Avatar
Exclamation lsx 376 injectors
I am in need of info. I have a lsx 376 b8 with fitech ultimate ls kit 750 hp with a persicion ls7675 turbo ,texas speed stage 3 cam 231/239, 640/ 629 115lsa cam 4l80 3600 circle d converter. The fitech comes with 55 lb injectors and I wondering if I should run bigger injectors? This is going in street car so I really dont know my limits on boost with this injector. I just want to start off with the right setup. I was considering running 10lbs and see what it would do.
Old Apr 22, 2018 | 09:07 PM
Lsxford's Avatar
What fuel will you be using? Can the fitech run low impedance injectors or high impedance? IMO 55lbers wont be enough for 10 psi, however your fuel pump(s), lines and regulator all have to be up to par also
Old Apr 22, 2018 | 09:52 PM
Stevef100's Avatar
Pump gas and high impedance
