Supercharger vs Turbocharger on a 99 TA LS| Auto Trans
Plenty of people on here have seen hot sides melt through brake/PS lines and wiring etc. That's not a negative? I said there are exceptions. People wrap the crap out of their hot side to prevent it but it happens to plenty of people and I can start listing members who it happened to. Its a fact of life something that gets to 1000* under the hood. Having had both, I can be subjective on the plus and minus of both, not just swinging on 1 side and ignoring the other.
Then to make it worse the factory installs the transmission cooler immediately in front of the AC condenser on those vehicles with a cooler (this compromises the efficiency of the AC condenser).
So to compromise, the factory sizes each larger to account for the less than 100 percent efficiency/effectiveness of each unit.
But as I said, it's a work in progress. Currently the engine doesn't overheat, the cabin is cool (better than stock) and the tranny oil temp is very low and far south of overheating.
And the Alky Control pump takes care of the somewhat elevated IAT's when in boost with a shot of methanol.
But there is still a temp differential compared to what it could be with the tranny cooler in a different location. To account for that will be moving the tranny cooler off of the face of the FMIC, fan assist it, and run some hose to direct air flow to it so it will be getting a good shot of fresh air.
That, I think, will cover all of the bases (radiator,ac condenser, tranny cooler, and FMIC).
I'm not here to argue whether one system is better or worse than the other. There are negatives and positives with each system. I pointed out one of the negatives with the ATI system (IMO). Note - I have an ATI supercharger.
The op will have to make his own decision as to which system to get.
-Want to skip dealing with feed/return oiling or having to run a scavenge pump? Turbo can't do that.
- Want to avoid the additional hot side piping under the hood and having to insulate or wrap wiring/PS/brake lines so it doesn't melt stuff? Turbo cant do that.
-Want to be able to do a cam/crank pulley swap without a large compressor sitting in front of the motor? Turbo can't do that.
-Want to mess with people while sitting at a stop light or car show and drawing some attention while idling? Turbo can't do that.
See how that works? lol, there's positives/negatives to both. Just like there are exceptions to some of what you listed and some of what I listed.
Restricted User
-Sounds like F-body problems
-Fbody problems.
-Anti-lag.
#32
Some of it comes down to intended use/driving style and even transmission.
I like my LSA supercharger and 6-speed, The instant boost makes acceleration smooth between shifts with not a hint of lag. My truck is also setup for handling with wide tires and big brakes. If I were to go with more of a drag setup with an auto trans then I would probably go with a turbo or maybe a centri.
You can make good power with any of them so like others have said you have to look at what works best for you and go with it.
If you want to go old school pro street look you can run an old roots style blower also.... Not very practical compared everything else available now but you can still make good power and have some bling sticking out of the hood lol
#34
That's the second time someone in this thread has denied the existence of boost control for supercharged setups, after describing how useful boost control is.
Why is it so rare? In theory it should just work and it should allow for a boost ****, boost coming on sooner, boost per gear... Does it not work well in practice? Or is it just that superchargers can work well enough without, so hardly anyone bothers?
I've been leaning that direction for my own car, but it seems to be rare... So i have to wonder if there's a good reason so few people do it, or if its just under-appreciated.
#35
Look at it from the view that a centrifugal supercharger is basically a belt driven turbo you should be able to control boost without issue.
Hell I can even control boost on my LSA supercharger a little. It has an internal wastegate that I can control with the Holley EFI I'm running. I can't dial in the amount of boost so much but I can control the wastegate enough to turn boost on and off, I'm not sure that it would act fast enough or well enough to keep boost at a set pressure. I could hook up a faster acting actuator but I use all the boost I have now so it's pointless.
#36
The complaint people have is that you're overdriving the blower for a given boost level....i.e. the blower may be spinning for 10psi but youre only actually using 5psi with the controller. I still haven't heard of anything breaking or blowing it up by doing this. The added benefit of doing this is the lowend/area under the curve is also increased because the blower is spinning faster.
#37
Does "overdriving the blower" really matter? (Provided you stay under the blower's max RPM, of course.) I mean, if airflow 5psi is vented (in that hypothetical example), so what if it's spinning fast enough that it would make 10psi without the wastegate? I'm guessing that stress on the belt/gears/bearings/vanes is more closely related to the actual boost than to the blower's speed. Seems like the earlier boost onset would be worth it.
On a related note, when tuning my Subaru it was really nice to be able to set the boost level with a manual boost controller. That gave me the ability to do repeated consistent pulls at any boost level, to dial in fueling and timing across the whole table. Or re-test the whole range just by twisting the **** between pulls. Now I wouldn't want to tune forced induction without that sort of convenience.
#38
On a related note, when tuning my Subaru it was really nice to be able to set the boost level with a manual boost controller. That gave me the ability to do repeated consistent pulls at any boost level, to dial in fueling and timing across the whole table. Or re-test the whole range just by twisting the job between pulls. Now I wouldn't want to tune forced induction without that sort of convenience.
#39
I have another question, does anyone know anyone any good turbo kits that have good price/performance that can get me into the 600/650 hp range? Also what will I need to upgrade to my car that's stock to have the turbo run? Fuel injection, Etc...?
My budget would be to try and get it under 10k, but I rather have to wait and get something good than rush something for cheap just to have it.
#40
You will need to find a good tuner.
After these two items - you now have about $9k left
It adds/subtracts real quick. See the post in the sticky about the costs for forced induction.
