pinning ATI Balancer
Old Apr 24, 2018 | 08:45 AM
rt338b's Avatar
Default pinning ATI Balancer
has anybody used the front type pinning tool to do a ATI Balancer? I know that ATI sells one to put pins in vertically but could you use the horizontal tool instead? Dont know if they have the same size centering bushing or not. Thanks in advanced
Old Apr 24, 2018 | 10:15 AM
forcd ind's Avatar
I did, main reason the vert one dug into the keyway on the balancer, made it hard to rem. I guess it tried to spin, and that caused it to dig in-so I went with the front type when reinstalled.
Old Apr 25, 2018 | 08:25 AM
rt338b's Avatar
Which one did you use? have seen several and don't know if they are all the same. Thanks
Old Apr 25, 2018 | 09:57 AM
forcd ind's Avatar
I used the Procharger kit, came with drill bit, pins, and jig-I would imagine there are others that look the same.
