Boosting my L92, too much cam?
Going to try and throw a turbo on my lq4/l92 over the winter. It's got a 225/230/111 with heads milled .030. Thinking of going with a 7875. Is this too much cam for this setup? I'm a bit concerned about the compression ratio as well. I'd appreciate your input.
Thanks
with the 7875 it should come in even sooner.....
The 225/230 111 cam is not too big, but it has a bit of extra overlap that you dont need. I would degree it to a 109* intake centerline, and run it.
I personally had excellent success with a 227/235 114 cam in my 6.0 with LS3 heads, S480 combo.
Barrett
But if I were shooting for a fun 600 wheel on pump gas and water/meth- I would not hesitate for a sec to run one again. I got bit by the s480 bug and while it makes a ton of power, it's not as snappy as the 7875.
My perspective is 800rwhp. If you are not looking for anywhere near that, then yes the 78/75 could work, but it will still choke the 6.0 up at higher rpm, which I don't like. I don't recommend it on any 6.0.
On my 6.0, s480 combo, I ran a 92mm turbine, 1.1a/r housing, and the thing spooled at 3K, and was an absolute blast to street drive with my 5spd on 10psi. That was 600rwhp.
It layed down 800rwhp on 16psi.
Barrett
btw i appreciate all the help. If any of you ever come to vancouver come by and we'll melt some tires
i dont plan on going over 7-8lbs any time soon. Supposedly this turbo is good to about 700hp. I did leave room to grow if I want to upgrade. My goal is only about 550-600rwhp and good manners.
